Adjustable Front Air Dam (pics)
Old 07-14-2005, 10:31 AM
CrossedFlags77
CrossedFlags77's Avatar
Default Adjustable Front Air Dam (pics)
A couple people in another thread asked me to post pics of my front air dam so here they are...
I built it in two stages. Initially I only had the dam section directly under the car, no front spoiler. Then I had the idea to put the spoiler on to cool it even more and hopefully keep alot of air from getting under the car, not that I would need it since I don't regulary see speeds over 90mph. I can adjust it up for when I am driving around town so I dont scrape on any parking lot entries or speed bumps. In the fully down position it is 3 1/2" off the ground.
First stage...
Did you do anything to the space around the headlights and such? I though about doing something there too since so much built up air is lost in that direction.
I only have a kick up at the back of the dam that meets up with the bottom of the radiator support. I didnt box anything in on the inside because I figured as long as I got a lot of air moving in the direction I wanted I would be fine. I had a 20 minute drive yesterday in 90' heat and my car was already warmed up and I didn't have to turn my electric fan on once. It stayed steady at 190' which is fine by me.
Old 07-14-2005, 10:37 AM
NHvette
NHvette's Avatar
Pretty slick fab work.
I'd take a black sharpy to the hardware, so it doesn't stand out.
Old 07-14-2005, 10:46 AM
CDaniel525
CDaniel525's Avatar
I want one! Even just for the bad **** factor!! LOOKS SICK!!
Old 07-14-2005, 11:03 AM
Star79
Star79's Avatar
Your car has the EXACT wheels on it that I want. What are they? (size/brand/did they fit without adaptors etc)
Old 07-14-2005, 11:22 AM
Twin_Turbo
Twin_Turbo's Avatar
I like the dam and the car, looks like nascar type basset wheels. You should market the dam.
Old 07-14-2005, 12:09 PM
mrtroutjedi
mrtroutjedi's Avatar
I buy one do you have a print so I can make one ?
Old 07-14-2005, 12:16 PM
rcread
rcread's Avatar
That looks great. It goes perfectly with the theme of the car.
Old 07-14-2005, 01:25 PM
CrossedFlags77
The wheels are American Racing AR767's 15x8 4"bs all around. I am using 1/2" spacers all the way around as well.
Thanks, I was initially going to buy the DOT approved Bassett wheels but they are out of stock for atleast a month and I couldn't wait that long. I have been thinking about marketing the air dam but I don't have time right now in between a full time job and get ready to go to college in a couple months, so we will see. I might see how much it would be to source it out if thats at all possible.
Thanks for the comments everyone.
Old 07-14-2005, 04:39 PM
Empatho
Empatho's Avatar
thats
Old 07-14-2005, 04:46 PM
WayneLBurnham
WayneLBurnham's Avatar
Default THAT is what the Dr. ORDERED!!!
Well, that gives me something perfect to copy, rather than invent!
Since I never go above FORTY FIVE MYSELF....[time for sheepish looks]...I guess I'd leave it at full down.
(Especially since my oil pan, tranny pan and lower edge of header conns are just under 3" off the deck - only the oil pan is armored.)
Hope to see it in person at a Cruiser's GTG a few weeks from now...
Old 07-14-2005, 08:35 PM
CrossedFlags77
Haha I drove home today from work and its about 85* outside. I couldn't get the car above 170* the whole way home with no electric fan and I was getting on it the whole way home.
Old 07-14-2005, 09:28 PM
Eddie 70
Support Corvetteforum!
Eddie 70's Avatar
Ci 6, 8 & 10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15
Pretty good idea. Would you happen to have some more pics that are taken in full sunlight so we can see it a little better. More airflow across the radiator is always a good idea and your idea looks good.
Old 07-14-2005, 10:48 PM
rosslato
rosslato's Avatar
Old 07-14-2005, 10:56 PM
Budman68
Budman68's Avatar
Cruise-In VII Veteran
St. Jude Donor '07
Did you put the rear spring on yet?
Old 07-15-2005, 10:36 AM
CrossedFlags77
I haven't yet. I need to go to Corvettes of Dallas sometime and get some new spring bolt bushings then I am going to install it.
Old 07-15-2005, 10:52 AM
NHvette
NHvette's Avatar
Tough to see from the pics... Did you leave the fiberglass
lower valence panel off and replace it with the steel ?
... or bolt the steel under the valence panel ?
Know what would be really slick ... somehow mount on a swivel
nut and use a piece of threaded rod on a power seat motor.
Then, it could be adjusted in the cockpit. You could add limit
switches for automatic height stops. Rotary encoders for digital memory,
or even speed sensing auto-height.
Old 07-15-2005, 11:23 AM
CrossedFlags77
I removed the fiberglass valence and just bolted up the dam.
That is a really cool idea, I might have to think about that.
To Adjustable Front Air Dam (pics)
Old 07-15-2005, 11:54 AM
Fevre
Fevre's Avatar
And a voice track that says 'Michael I sense a speed bump ahead so I am raising the spoiler' plus a red light that strobes back and forth.
Old 07-15-2005, 03:01 PM
WayneLBurnham
Default Hey! They ALREADY call mine "KITT"!!!
Well, when even "the peasant's porsch...uh" (the new VW turbo thingy) has a couple of automatic spoilers...man, it's just HARD to not do something like that!!!
Old 07-15-2005, 04:22 PM
Empatho
Empatho's Avatar
Quick Reply: Adjustable Front Air Dam (pics)
