Best Way to Clean Aluminum Intake Manifold??
What is the best way or product to clean an aluminum intake while it is in the car. Has old silver dressing on many areas. Someone said brake fluid, another oven cleaner,--don't want to take the paint off the car--just clean the intake.
Busch Aluminum Wash. It comes in various strenghts. The heavy duty cleaner has acid in it but it states in the product discription that it's for intakes. Just be carefull with it.
http://www.buschshineproducts.com/in...vuosnjr6r1dsd5
I think something like Simple Green brushed on to the manifold (and carb bodies, too) would clean up that light oil residue. Just seal off the inlets to the carbs and 'trash bag' the ignition stuff. Rinse off and let dry.
Easy-off oven cleaner (with care) will clean almost anything off the intake. Brak-kleen will too.
If you can seal off (whatever) and use Eagle1 cleaner that is used for aluminum, non-clear coated wheels, it'll shine like new money. I used that stuff on my 25 year old Centerline wheels. It turns the aluminum white after 15-20 secs., then just run water over it to neutralize the acid. Works good, lasts long, goes real fast!
I had an article about Simple Green. Ya gotta be careful with that stuff. It causes hydrogen embrittlement on a Harley-Davidson springer front-end. I would imagine it will damage other items too. I quit using it when I found this out (I own a Harley, but not a springer)
We all appreciate it just as much as you do. My car wishes that it was a big block. I told it that I would think about it...
