Battery Disconnect Switch
Old 10-21-2009, 01:40 PM
ArthurMartin
ArthurMartin's Avatar
Default Battery Disconnect Switch
What type of battery disconnect switch do you guys use? I'm trying to figure out if I have a bad ground of what. I use a battery maintainer on a new battery but it keeps losing its charge when the car sits for a while. The only thing I know that is running is the dash clock.. Anyways, I figure the easiest way in the meantime is to disconnect the battery while the car is not in use with a battery disconnect switch. Thanks in advance for any help.
Old 10-21-2009, 02:23 PM
427basketcase
427basketcase's Avatar
This is what I use, it works very well (after installing it, which can be challenging)
http://www.zip-corvette.com/ProductD...BS-SR&CTitle=&
Old 10-21-2009, 02:58 PM
1ATony
1ATony's Avatar
They have them at places like Autozone. I had one on my car they work pretty good.
Old 10-21-2009, 03:33 PM
Paul L
Paul L's Avatar
Wirth blade disconnect. The extra wiring is for a subwoofer.
Old 10-21-2009, 03:42 PM
ED79
Support Corvetteforum!
ED79's Avatar
Easy to operate, got mine at Advance Auto
Old 10-21-2009, 04:09 PM
ArthurMartin
Nice thanks for all of the help.
Old 10-21-2009, 04:49 PM
outlawkinser
outlawkinser's Avatar
I bought the same disconnect that Paul used. Got it from J.C. Whitney. Unit works great. I like it better than the **** unit.
Old 10-21-2009, 04:57 PM
Lon Wayne
Lon Wayne's Avatar
Default Vader Vette
Go to your local napa they have the same switch no waiting . I use it on my camper 12 volts. my vett batt stays charged all season by its self Store it in Oct Starts right up in the spring clock running and all. you must have a small batt drain, if the fuses wernt so hard to get to I would say take them out(one at A time) shut out the flash light and plug it back in when you see a spark track down that fuse and see what all it runs.
Alan 71
Alan 71's Avatar
Received 2,878 Likes on 2,515 Posts
Hi,
Although I like the **** type disconnect, I've noticed that because the ground cable is so stiff, it can twist the loose part of the switch when the **** is turned part way so a connection can still be made. I'm now removing the **** completely and moving the ground cable aside to be sure.
So perhaps Paul's knife type dissconnect is the one to use.
Regards,
Alan
Old 10-21-2009, 05:12 PM
...Roger...
...Roger...'s Avatar
Originally Posted by Alan 71
Hi,
Regards,
Alan
Allen here is how you can fix that little problem. Just add a couple zip ties and the problem is solved.
Old 10-21-2009, 05:21 PM
rajsid
rajsid's Avatar
Don't get the Corvette Central kind. They may look similar to what other vendors are selling. It's just that they are always on back order.
Old 10-21-2009, 06:52 PM
nutsy
nutsy's Avatar
i have same one. no problems, easy to install. (blade type)
Old 10-21-2009, 07:59 PM
wills670
wills670's Avatar
This is the switch I have on mine. It is a cole hersee quarter turn. I just used a short cable to the batt. and then removed the bolt from the regular negative cable and installed it on the other side. I routed the cable so there was no possibility of it coming in contact with the possitive side. It works very well just open up the compartment and a qurter turn and your ready to go.
Old 10-21-2009, 08:07 PM
vetteguy75
vetteguy75's Avatar
LA Events Coordinator
Old 10-21-2009, 09:10 PM
onaqwst
onaqwst's Avatar
buy 2 and put 1 one each side.... i would rather kill the hott then the ground though if i had 1....
just saying....
Old 10-21-2009, 09:47 PM
72LS1Vette
72LS1Vette's Avatar
I put a blade switch on the + side of my battery because I have a wire from the terminal side of the switch connected to the ECU memory and I need the ground connected. There have been some discussions of disconnect switches in the past. Some use them on the + side and some on the ground. Either way works, and I'm not sure if there was ever a consensus on which side produces more sparks when connecting. I have not seen any sparks from my switch when connecting the + side.
Rick B.
Old 10-21-2009, 10:46 PM
7dSHARK
7dSHARK's Avatar
i would like to see a photo of that,,matt
To Battery Disconnect Switch
Old 10-21-2009, 11:31 PM
Erik016
Erik016's Avatar
I use a hella
http://www.summitracing.com/parts/HLA-002843011/
The key is removable so it also works as a theft prevention device.
Old 10-22-2009, 08:01 AM
Ganey
Ganey's Avatar
The large switch w/ the **** in the beginning of the topic will work for many. Neg. side rec. esp. for the large switches.
I prefer this type.
This is the switch I have on mine. ...
Old 10-23-2009, 01:50 PM
wills670
wills670's Avatar
Here is a pic. I did not want to drill any holes to mount so it is just laying in there.
Quick Reply: Battery Disconnect Switch
