Aftermarket spark plug wire routing, PICS?
Old 12-17-2009, 07:45 AM
cosmicvette
cosmicvette's Avatar
Default Aftermarket spark plug wire routing, PICS?
Hi all,
Really don't like the factory routing, what should be a 5min job to change the spark plug wires is made an hour long saga trying to feed those damn wires through and underneath the motor. I am after a setup that comes across and down over the valve covers (so all the wires are all easily accessible), would love to see pics of peoples setups also what lengths the wires are, the manufacturer, and the manufacturer of any brackets etc that hold/route the wires.
Thanks,
cosmic
Old 12-17-2009, 08:06 AM
MrJlr
MrJlr's Avatar
For a momment...just for a second, pretend it's a Camaro..! Seriously, I bought a set you cut to length and ran them "normal" on the top side of the engine. Sorry no pics...I'll try to snap some tonight and post them.
Old 12-17-2009, 08:24 AM
pippo350
pippo350's Avatar
You can buy a wire loom.
Wait and I'll post the picture of the mine.
Old 12-17-2009, 08:27 AM
Jughead
Senior Member since 1492
Support Corvetteforum!
Jughead's Avatar
Location: Just because I'm paranoid doesn't mean people aren't out to get me...
St. Jude Donor '09
Old 12-18-2009, 02:43 AM
lilmonster
lilmonster's Avatar
Mine was already done when i bought it, but i noticed they cut slots in the original wire covers so the wires could come out on top of the valve covers.
Old 12-18-2009, 01:01 PM
C3 4ME
C3 4ME's Avatar
Mine run along the bottom rail of the valve covers and drop off one at at time at each cylinder.Name:  2007_0521Corvette0005.jpg
Old 12-18-2009, 01:48 PM
7t2vette
The ORIGINAL and bestest
7t2vette's Avatar
Toronto Events Coordinator
Universal MSD 8.5mm Super Conductor wires cut to fit alongside the valve covers in R&M Specialties #1101P looms. You would need to pick the wire set based on your distributor cap type. These are what I used:
http://www.summitracing.com/parts/MSD-31239/
http://www.summitracing.com/parts/RNM-1101P/
Old 12-18-2009, 02:04 PM
terry82
terry82's Avatar
i thought i was the only one who thought it was dumb to put the wires back to stock routing.
Old 12-19-2009, 03:40 PM
bobs77vet
bobs77vet's Avatar
Location: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
i like 7t2vettes routing very much and will do that next time
Old 12-19-2009, 03:57 PM
lilmonster
lilmonster's Avatar
Great Thread.
Not only seeing other great ways to route your wires,
but you also get to see so many different valve covers.
Old 12-19-2009, 06:09 PM
toddalin
toddalin's Avatar
Received 1,186 Likes on 490 Posts
Old 12-19-2009, 06:16 PM
dmeesq
dmeesq's Avatar
The following 2 users liked this post by dmeesq:
PHIL 68 (02-07-2017), seafox210 (02-24-2017)
Old 12-20-2009, 06:55 AM
aussiejohn
aussiejohn's Avatar
Default Nice engines!!!
72Vette,
I really like your engine layout, especially the top radiator hose. That is the way I want to do mine. Also like the spreader bar - ahhh, there's so much inspiration here. Keep up the good work.
Regards from Down Under
aussiejohn
Old 12-20-2009, 07:26 AM
noonie
noonie's Avatar
Not a fan of it either. Seemed to look good and work well for many years. I just wonder how many chased problems from this setup.
It makes a big difference if you use headers vs the oem cast manifolds. No problem with headers.
It would be great to see better pics of lilmonster's car showing from the valve covers down to the spark plugs. That's the problem area.
In one of Smokey's findings, referenced in old books, he mentioned how it is important to keep the wires at least 1 inch apart to prevent higher rpm spark jumping and his experiences with it. Wires are better now, but in the 60's he also condoned a coil/cyl. Also good insight.
Old 12-20-2009, 03:22 PM
lilmonster
lilmonster's Avatar
Ok, since I happen to be working on it today, I'll get another pic.
Old 12-20-2009, 04:43 PM
OURSHARK
OURSHARK's Avatar
This is how I ran mine.
Old 12-20-2009, 06:11 PM
autoist
autoist's Avatar
I'm at that point right now....hope my distributor arrives Monday from the rebuilder:
I wanted mine to blend into the engine & not stand out.....oh, car is a '77.
To Aftermarket spark plug wire routing, PICS?
Old 12-20-2009, 10:54 PM
bobs77vet
bobs77vet's Avatar
thats a sweet engine what hood are you going to use?
Old 02-06-2017, 10:05 PM
r16678
r16678's Avatar
Does anyone know if this aftermarket kit will work if I use the stock exhaust cast iron manifolds?
Old 02-07-2017, 06:40 PM
LRB
LRB's Avatar
Here is what I did on my 75. I used the wires that you make up as you go.
Quick Reply: Aftermarket spark plug wire routing, PICS?
