69 Interior redo
Old 12-30-2010, 05:10 PM
EricU
EricU's Avatar
Default 69 Interior redo
Well, it is time to redo my interior on my 69. As I just got the EFI worked out after missing the last three (yes three) summers of top down driving here in California, I REALLY dont want this interior project dragging on.
So far I have ordered my interior kit from Wilcox which includes:
· Seat covers – black leather
· New seat foam
· New door panels - black
· New carpet – black
I have new AutoMeter gauges of which I will be trying to force 2 5/8" guauges into 2 1/8" holes (but that is a different problem).
I have read somewhere else on this forum about a spray on underlayment product (Gator-something?), should I use a spray on underlayment or a bunch of mat material?
Will I need to get the assembly manual (AIM?)?
Where do I get a assembly manual and are they available in pdf?
I need to clean up the rest of my interior while I am at it. I plan on first cleaning and dying the parking brake console and the center shifter console black.
I have read that the Sem dye products are good products to use.
· How do I clean/prep these pieces? Soap & Water
· Which of the Sem products do I use for;
o Cleaning
o Dying
· Do I just use black dye or dye & some kind of clear coat?
· Which black do I use (they seem to have more than one)
For the center shifter console trim plate;
· How do I prep it
· What should I paint it with?
· What finish should it be, flat, semi, gloss (hope not!)
Thanks, Eric
Old 12-30-2010, 05:56 PM
JW3101
JW3101's Avatar
St. Jude Donor '11-'12-'13-'14-'15-'16-‘17-‘18
BEFORE
AFTER
BEFORE
AFTER
You need to use SEM Black - I prepped the pot metal for the shifter plate console with SEM Self Etching primer. I got all the info on redoing the console from the forum threads. The most tedious part was cutting painters tape with a razor knife to cover all the chrome edging and then pulling it off with tweezers. Just be careful not to go overboard with paint, several lights coats should be all you need and make sure you give it time to set-up between coats.
I even repainted the horn button - I was going to replace, but it came out pretty good. I also replaced the ugly shifter and put a Hurst OEM style shifter back in.
You shouldn't need the AIM for this job, but you should have one. All of the vendors have them - Wilcox has it as well. The PDF verson is nice, but sometimes you will need it on the garage floor next to your parts, etc.
You should look into buying the 1969 Stingray Guidebook - it's kind of like the bible for the '69. Crane's Corvette sells it. http://www.cranescorvette.com/1969_s..._guidebook.htm
Old 12-30-2010, 07:01 PM
RobRace10
RobRace10's Avatar
There is Lizard Skin which is a heat barrier. I used some home made product using paint and micro spheres on the underside and top side, then put down Dynamat and Dynaliner.
http://forums.corvetteforum.com/c3-g...-pictures.html
http://forums.corvetteforum.com/c3-t...-material.html
On top of this I installed the dynaliner.
Old 12-30-2010, 11:10 PM
EricU
EricU's Avatar
Originally Posted by JW3101
You need to use SEM Black...
Which of the Sem's products did you use?
  • Sem Color Coat?
  • Sem Clasic Coat? (I think this is the one for leather and not hard plastic)
  • Sem Sure Coat?
  • Sem soap?
  • Sem vinyl prep?
Did you use the aerosol cans or the pint that go through a sprayer?
And which black as they have more than one black?
  • Landau Black
  • Satin Black
  • Gloss Black
  • Graphite
...I prepped the pot mettle for the shifter plate console with SEM Self Etching primer...
When you say the pot metal, do you mean the center shifter console trim plate?
I can't tell from your photos, is your shifter console trim plate painted black?
...The most tedious part was cutting painters tape with a razor knife to cover all the chrome edging and then pulling it off with tweezers. Just be careful not to go overboard with paint, several lights coats should be all you need and make sure you give it time to set-up between coats.
Did you spray can paint or use some Sem product on the center shifter console trim plate?
And if this was a different product than the Sem, what product and what finish (flat, semi or gloss)
BTW: your steering wheel came out great!
Thanks, Eric.
Old 12-30-2010, 11:19 PM
EricU
EricU's Avatar
Lizard Skin is the product I was thinking of.
Is the Lizard Skin only a heat barrier and the Dynamat used for sound deadening?
Thanks, Eric.
Old 12-31-2010, 10:26 AM
RobRace10
RobRace10's Avatar
Thanks, Eric.
They sell two spray on products. Just Google Lizard skin. Summit sells it.
I used the stuff I mixed as a heat barrier, Dynamat is a sound control and dynaliner as a heat barrier.
Old 01-04-2011, 11:00 PM
JW3101
JW3101's Avatar
[QUOTE=EricU;1576370927]Which of the Sem's products did you use?
  • Sem Color Coat?
  • Sem Sure Coat?
  • Sem soap?
  • Sem vinyl prep?
Sem Trim Black #39143
Sem Self Etching Primer Black #39673
They're both in aerosol cans.
  • Landau Black
  • Satin Black
  • Gloss Black
  • Graphite
Yes, the entire center console trim plate section is made of pot metal.
Yes, the shifter console trim plate is painted black.
Everything was SEM aerosol cans. I got the information on the redo from the forum and Alan71 was a big help!
Thanks!
Also, you're ashtray/cig lighter sliding door is also black and you can use self-etching primer and the SEM Trim Black.
Sorry I didn't get back to you sooner - just finishing up on a kitchen remodel and couldn't get to the cans of SEM until I pulled all the new cabinets out of the garage.
To 69 Interior redo
Quick Reply: 69 Interior redo
