Goodbye Big Block/4spd...Hello LS2/6speed...
Old 04-04-2014, 09:42 PM
  #141
Corey_68
Corey_68's Avatar
Thanks Gordon and Terry, I'll try to recalibrate it again.
Just need to figure out the tach..
Old 04-05-2014, 02:54 AM
  #142
DEEPSEA70
DEEPSEA70's Avatar
Default Tach
I used a Dakota Digital tach interface. My harness had an input from the ECU. I converted my 70 mechanical tach with a 75 electric tach that plug right into the Dakota. You have to select the correct 4 cylinder cycle since the ECU puts out half the signal. It seems to work in line with my scanner, but I have to drive it still.
Old 04-05-2014, 07:36 AM
  #143
Gordonm
Gordonm's Avatar
Ahh. That is right. I remember the switching to a 4 cylinder mode. I'll have to give that a try. Thanks
Old 04-06-2014, 02:20 PM
  #144
Corey_68
Corey_68's Avatar
Gordon, not sure what tach you're running but I have an Autometer ultra lite #4498. For this model it calls to reduce the pulse by clipping the Brown and orange wires. Problem is, I do not see Brown or orange wires coming out of this tach.
Looks like I will be calling Autometer tomorrow.
Old 04-06-2014, 04:15 PM
  #145
riggs 74
riggs 74's Avatar
Corey, these are the instructions I pulled from auto meter for the 4498. It says that you change the setting by way of switches, but it also says that it's factory shipped for use on 8 cylinder use. Check to see if yours is this way, if not it may be defective.
http://www.autometer.com/productPDF/1185.pdf
Terry
Old 04-07-2014, 05:13 PM
  #146
Corey_68
Corey_68's Avatar
I thought I had the switches but couldn't see then until I removed the tach. They are really, really small and had to use a toothpick to change the seetings.
Old 04-26-2014, 02:30 PM
  #147
Corey_68
Corey_68's Avatar
Finally able to drive the car today, tack is fixed and accurate. Tried to recalibrate the speedo again, still does not go too full sweep only 3/4, but if it's off it's not by much. I'll test it against my gps.
Old 04-26-2014, 04:05 PM
  #148
myoriginal77
myoriginal77's Avatar
I did this 10 years ago ( Yikes ) with an LS1 & T56.
It's much easier now, back then there were very few parts being made for these swaps.
It's the best thing I ever did -
Happy Motoring
Frank
Old 04-26-2014, 07:40 PM
  #149
riggs 74
riggs 74's Avatar
Glad to see the tach problem resolved. Now its time to drive and enjoy it. The ls motors are a really nice upgrade for the C3's
Im going tomorrow to have mine retuned, looking to gain a few more horses and clear up a few things in the current tune.
Terry
Old 04-26-2014, 07:59 PM
  #150
Corey_68
Corey_68's Avatar
Terry
Thanks Terry, , I plan to put some miles on it tomorrow weather permitting.
Let us know what numbers you pull!
Old 04-27-2014, 04:11 PM
  #151
Corey_68
Corey_68's Avatar
Put 40 miles on her today,.speedo is only off by maybe 2mph per the GPS, I can live with that considering the stock gauges in ourr cars are not terribly accurate in the first place.
Second the cooling system held up like a champ, most of the drive was moderate to having traffic. At one point I had to sit through 3 red lights. The temp never got above 205.
Old 05-22-2020, 09:56 PM
  #152
Corey_68
Corey_68's Avatar
Lifes been crazy and finally getting some time to work on the Vette.
Disassembled and dropped her off for some minor bodywork and paint today.
Gordonm (05-23-2020)
Old 03-18-2021, 10:36 AM
  #153
Corey_68
Corey_68's Avatar
After 30years, paint is looking tired and is in for a nip/tuck. Project took longer that anticipated but they do fantastic work, paint should go on today or tomorrow.
Changing the color, will be quite a difference in hue.
Hopper12 (03-18-2021)
Old 03-18-2021, 11:45 AM
  #154
69_Shark
69_Shark's Avatar
Nice choice for the red.
I was wondering who reserected this post! LOL!
Scott
Old 03-18-2021, 12:25 PM
  #155
Corey_68
Corey_68's Avatar
Scott
Thanks Scott, I hope it looks great....It's been a hell of a journey.
Old 03-18-2021, 04:54 PM
  #156
69_Shark
69_Shark's Avatar
Yeah, I am there with you! LS swap, lots of other stuff too!
I would like to paint also but not yet!
Scott
Corey_68 (05-04-2021)
Old 05-18-2021, 04:42 PM
  #157
Corey_68
Corey_68's Avatar
Ole girl is coming along....Hope to starting putting her back together soon.
The following 5 users liked this post by Corey_68:
DanStp (05-19-2021), gdh (05-18-2021), J Bennett (05-18-2021), leigh1322 (05-18-2021), taint (05-18-2021)
To Goodbye Big Block/4spd...Hello LS2/6speed...
Old 05-18-2021, 05:24 PM
  #158
taint
taint's Avatar
That looks great, but Jesus! You started this 10 years ago...? Perseverance!
Corey_68 (05-18-2021)
Old 05-18-2021, 05:44 PM
  #159
Corey_68
Corey_68's Avatar
...Seems like that long, that is for sure. Truth be told, I was driving it about 8months after the swap.....setup was a game changer for me,, I took the car down to the family shop around 3 years ago for paint and life got in the way and was delayed. I'm just looking forward to putting it back together and driving it again.
Old 05-18-2021, 05:58 PM
  #160
cv67
cv67's Avatar
Received 3,043 Likes on 2,602 Posts
St. Jude Donor '05
So looking back what are the pros and cons in your opinion of both powerplants?
Quick Reply: Goodbye Big Block/4spd...Hello LS2/6speed...
