wonder about quater mile and 0-60 times
Old 08-09-2011, 12:40 AM
chinohillhuskie
chinohillhuskie's Avatar
Default wonder about quater mile and 0-60 times
Have a 1974 corvette with a L82 350-Ci that has 250 horses
wonder what the times would be
I also want to know the best way to gain more horsepower for
under 500 dollars
Old 08-09-2011, 01:54 AM
Aussie79
Aussie79's Avatar
I just tested my L48 79 basically stock car, dunno about quarter mile but 0-60MPH was 7.2 seconds which is about what it was in 1979 according to all I have read, I'm happy with that, what I'd like is better MPG.
As for $500 for more HP, well, buy 5 $100 horses is my only suggestion...... *sorry*
Old 08-09-2011, 06:29 AM
PG99
PG99's Avatar
What rear end do you have?
Also do an internet search for your year there will be the specifications listed with all that info
Old 08-09-2011, 07:11 AM
Paul Workman
Paul Workman's Avatar
Default More air in & out = more HP
Under $500...Hmmmm.... Well, the old saw is: "Speed cost money. How fast do you want to go?"
  1. Low restriction air filter (K&N?)
  2. Cold air inletting is a good thing (denser air, doancha know)
  3. low restriction cat(s)
  4. true dual exhaust (if it is smog legal where you live)
  5. cam and lifters upgrade...
  6. LT headers
  7. Yada, yada, yada...
And, no matter what mods you do, a fresh tune is usually a good way to make the most of whatever you have. E.g., advance the timing, but that might mean having to switch to 91+
Are your going to get this all for under $500? No way. And, having built and rebuilt many a motor, I have found I get more bang for the buck by setting a goal for the build and selecting the stuff to get there and (try to) avoid my natural urge to over-engineering/build everything.
Oh! And, don't fall for all those "miracle" gimmics, e.g. the likes of the "Tornado"
If you care to set a hp goal and state how you're going to use the car, and post it here, there's some really sharp dudes here to help you get there relaibly with the least amount of $$. (And it will be tried and true - read: no gimmics!)
P.
Old 08-09-2011, 07:57 AM
gbvette62
gbvette62's Avatar
Received 2,031 Likes on 1,316 Posts
Around 1980, I had a 74 L-82 with a 4 speed and a 3:70 rear gear. All stock, the car ran high 14's.
Old 08-09-2011, 08:14 AM
nate99
nate99's Avatar
http://www.zeroto60times.com/Chevrol...mph-Times.html
1973 Corvette (350ci) L82 0-60 mph 6.6 Quarter mile 14.9
1979 Chevrolet Corvette L82 0-60 mph 7.2 Quarter mile 15.5
Old 08-09-2011, 08:52 AM
bashcraft
bashcraft's Avatar
'74 L-82 - 0-60 in 7.5 seconds.
Old 08-09-2011, 02:03 PM
toddalin
toddalin's Avatar
Received 1,167 Likes on 486 Posts
Easiest way to gain BIG hp for <$500 is nitrous, but you probably don't want to go that route.
Best bang in your range are cam and/or headers (and maybe not even headers anymore).
Of course you could buy a moto-tool and a bunch of sandpaper rolls and pocket port and blend your own heads for next to nothing and this would be a major benefit.
Old 08-09-2011, 02:09 PM
RonR80
RonR80's Avatar
St. Jude Donor '09
I went with intake ,21/2 inch exhaust no cats, and a mild cam , made a big difference. Dynoed 221HP at the wheels. 80 L-48
Old 08-09-2011, 02:30 PM
Easy Mike
Support Corvetteforum!
Easy Mike's Avatar
Received 1,469 Likes on 1,248 Posts
Cruise-In II Veteran
Originally Posted by chinohillhuskie
...Have a 1974 corvette with a L82 350-Ci that has 250 horses wonder what the times would be...
Take it to the track and find out.
...I also want to know the best way to gain more horsepower for under 500 dollars...
Tube headers and a tune up.
Old 08-09-2011, 02:49 PM
PRNDL
PRNDL's Avatar
LS engine would do it. (not < $500 )
To wonder about quater mile and 0-60 times
Quick Reply: wonder about quater mile and 0-60 times
