body mount bolts
Old 05-07-2012, 09:14 PM
merc49
merc49's Avatar
Default body mount bolts
im putting my 75 body back on the chassis and need to know the bolt lengths for each mount,or are they all the same.i had to cut them all off and am using the poly body mounts.is there a difference as opposed to using the rubber mounts.i dont want to buy a bolt kit because i have all the free bolts i can use at work.
Old 05-07-2012, 10:17 PM
I'm Batman
Support Corvetteforum!
I'm Batman's Avatar
St. Jude Donor '07
Poly and rubber should be the same height. This is one of the rare cases where I'd suggest getting the correct bolts - you want a smooth shank in the bushing area, and the factory-style bolts have a flare under the hex head to help spread the load.
Old 05-08-2012, 11:12 AM
my 76 ray
my 76 ray's Avatar
Same length bolts all around. I reused some of my originals on my poly mounts. The poly mounts have a metal sleve so I don't know if it would make a difference if the bolt had threads in that area. You could use a flat washer to spread the load. It's your call.
Old 05-08-2012, 01:16 PM
bobs77vet
bobs77vet's Avatar
Location: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
i think i bought 3 and 3 1/2" bolts for the back mounts when i replaced them cant remember which one i used though...like you said they are nothing fancy
Old 05-08-2012, 02:34 PM
Mcgann454
Mcgann454's Avatar
Just replaced all of mine with 3" grade 8 bolts from Rural King. Buy it by the pound.
To body mount bolts
Quick Reply: body mount bolts
