door panel removal
Received 2,878 Likes
Hi ST,
It's a bit involved.
First the window winder (if std. windows), and lock ****, need to have their clips released using the special tool for that purpose, or a piece of cloth, or piece of dental floss.
Then the hidden screw at the inside/base of the door lever needs to be removed so the lever can be slid off the opening mechanism.
Then there are screws at the clips (1 each) on the lower front and rear edges of the panel that need to be removed.
Then the 2 screws that go through the panel at the top corners.
Now the bottom of the panel can be pulled outward to release the velcro-like fasteners across the panel's bottom edge.
Finally the panel can be lifted up to release it's upper edge that clips over the door frame at the slot for the window.
Good Luck!
Regards,
Alan
Do you happen to have the 72 Assembly Manual or Chassis Service Manual? Either of those would help.
Good Luck!
Regards,
Alan
Former Vendor
Received 1,813 Likes
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
Alan is on target, and here is a picture that will help you understand what items he's talking about.
Hi,
You do need to be careful using the tool to remove the clip for the lock ****.
The width and shape of the tool makes it easy to scratch the chrome/black trim in the area of the ****.
Regards,
Alan
Regards,
Alan
Former Vendor
Alan.. One tool I've used which will reduce that risk (and I suppose I should change the picture above) is the pick below. If you place a flat tip screw driver between the **** and the insulator and gently twist, you can slip the pick behind the **** and pull the clip out without damage.
just a note on mine (its a 75 not a 72) there are 2 screws in either end of the door handle pull. shown on Wilcox's diagram.
I just pulled mine for the first time today to see why these things are so expensive. I guess I understand now. They are more substantial than I thought.
Cant afford more than one at a time right now but Ill be giving Wilcox a ring soon to replace my right side.
Hi Willcox... is it Ernie?,
I've been using a loop of dental floss for years.
Once you've done it once or twice it's pretty easy to snag the clip with the floss on the first try.
I scratched my trim years ago with the tool.
So many little tricks to getting an interior apart and then back together without damaging all those fragile, costly, parts.
Regards,
Alan
Regards,
Alan
Former Vendor
Regards,
Alan
Regards,
Alan
I'll have to modify that picture so that others will know the "easy" way.
