Quadrajet fuel filter nut stuck, now what?
Old 08-11-2013, 03:19 PM
rene040269
rene040269's Avatar
Default Quadrajet fuel filter nut stuck, now what?
Tried to remove the steel fuel line to my Qjet to clean the fuel filter but the inner small nut is rusted solid to the larger nut. The small nut starts to round-off but is not going to move. If i strip it i am in deep sh*t i do not have a new fuel line. Any tips on how to remove this little bugger?
Old 08-11-2013, 03:51 PM
bondoboy
bondoboy's Avatar
Hold the large nut with a 1" wrench, I believe. Remove the fuel line using a vise grip if you need to. The line and nut are probably shot anyway, especially if it already started rounding off. Fuel lines are easy enough to get. Last time I checked, I had trouble getting new quadrajet fuel filter nuts.
Old 08-11-2013, 04:09 PM
carjack007
carjack007's Avatar
Buy a new fuel line. Cut old line about 3" long with tubing cutter or hack saw. Remove large nut with the proper box end wrench. Put large nut in a vice. Use a vicegrip to remove small nut. If you have to, you can join the cut fuel line with rubber fuel hose and hose clamps temporarily. Hope this helps.
Regards, Bob
Old 08-11-2013, 05:20 PM
Jeff_Keryk
Jeff_Keryk's Avatar
You are using a 5/8" tubing wrench, right?
Just checkin...
Old 08-11-2013, 08:32 PM
jnb5101
jnb5101's Avatar
use a 6 point wrench.
Old 08-11-2013, 09:00 PM
bpassmore
bpassmore's Avatar
Soak it with penetrating oil, you do not want to damage the carb's internal threads at the filter nut. Take it easy!
Old 08-12-2013, 09:39 AM
ramair_bryan
ramair_bryan's Avatar
Heat it up with the torch............................
Old 08-12-2013, 12:37 PM
oldC3guy
oldC3guy's Avatar
You might be stuck doing what some of the guys are suggesting above. But also note that they are talking about what I call a "flare nut wrench" to use on nuts like the one you are having trouble with. If you wind up having to replace the line, you should consider getting this tool to help with future projects like this. Regular open end wrenches are notorious for rounding off hex nuts.
Old 08-12-2013, 01:55 PM
Easy Mike
Support Corvetteforum!
Easy Mike's Avatar
Received 1,469 Likes on 1,248 Posts
Cruise-In II Veteran
Originally Posted by oldC3guy
..."flare nut wrench"...
Flare nut wrench.
Old 08-12-2013, 03:30 PM
imariver
imariver's Avatar
Get the entire set, as you'll be needing them on brake tubing and other projects.
Old 08-13-2013, 04:05 AM
rene040269
rene040269's Avatar
Thanks guys, i'll get me a set of flare wrenches soon, the brake lines look indeed like i am facing the same problem removing these.
For now, i will cut the steel fuel line and remove the filter/nut in a vice, i do not want to put force on the hard line while connected to the carb. A fuel line is much more easy to replace than a stripped out thread in my carb.
Rene
Old 08-13-2013, 09:55 PM
gcusmano74
gcusmano74's Avatar
Try putting a strain on the nut with your flare nut wrench, and then give the wrench a tap or three with a SMALL hammer.
Use anti-seize when reassembling.
Old 08-14-2013, 09:28 AM
jnb5101
jnb5101's Avatar
if you're going to cut the steel fuel line, don't bother with the flare wrench. it's a 1" nut, so finding a flare that large is difficult, and a regular closed 6 point wrench will not flex when you apply force. as posted above, give it a few easy smacks with a small hammer and the shock will loosen the nut.
Old 08-14-2013, 12:32 PM
Jeff_Keryk
Jeff_Keryk's Avatar
Actually, I think you will find the flare nut wrench is used for the 5/8" fuel line nut, the 1" wrench is for the filter housing.
I have a thin Snap-On 1" open-end wrench that works real well for this purpose.
Old 08-14-2013, 03:24 PM
my 76 ray
my 76 ray's Avatar
Spend the money on a good set of flare nut wrenches. The cheap ones aren't any better than an open end. I would say "Craftsman" quality at a minimum.
There's not much chance of messing up the threads in the Carb as long as you only HOLD the 1 inch filter housing and don't turn it.
If you do decide to cut the fuel line then a 6 point socket will probably remove the flare nut.
Old 08-14-2013, 03:30 PM
bpassmore
bpassmore's Avatar
Very important!!!!!
To Quadrajet fuel filter nut stuck, now what?
Quick Reply: Quadrajet fuel filter nut stuck, now what?
