dye coloring
Received 1,469 Likes
Cruise-In II Veteran
FWIW: Purchase replacement carpet trim in the color you want. I've heard the interior dyes not work too well on carpet; it doesn't get down into the loop.
I agree with easy mike. Did my blue carpet many years ago to black with dye and it didn't look very good. Have heard some using rit dye for clothing but that would require taking the carpet out. Would be much better to replace the carpet. The vinyl interior parts however will come out nice. I recently renewed some with duplicolor flat black interior dye from Orielly auto parts. I also had a can from Corvette America that I tried. Both do a great job the duplicolor is less expensive.
Mark Smith
Mark Smith
What I mean is any where you put your feet or in the back when you store your tops.......over time it will wear off .Also the carpet becomes stiff after dying.......So like said above new carpet is the best but if money is an issue dye works fine.
