73 hood interchange
Old 10-01-2013, 09:53 AM
4 speed
4 speed's Avatar
Default 73 hood interchange
what year hoods will bolt directly to a 73. not for stock appearance.
looking for a bigger cowl or LT1 or L88 hood.
I see references to 73-76, 77-82, 73-82, 73-75, and everything inbetween ???
Old 10-01-2013, 10:02 AM
Easy Mike
Support Corvetteforum!
Easy Mike's Avatar
Received 1,469 Likes on 1,248 Posts
Cruise-In II Veteran
Nothing stock LT-1 or L-88 will bolt up to a 73 or later car. If you want LT-1/BB for your 73, you will have to purchase an aftermarket hood.
Old 10-01-2013, 09:49 PM
4 speed
4 speed's Avatar
I know 72 and earlier won't work due to wiper door, but if I were to fing an after market l88 from a say 78 would it fit my 73 ???
Old 10-02-2013, 08:54 AM
Easy Mike
Easy Mike's Avatar
Hood latch hardware is different. You want an aftermarket 73 and later hood using 73 latch hardware.
Old 10-02-2013, 09:42 AM
4 speed
4 speed's Avatar
so any 73 or later hood will fit with proper latches ?
Old 10-02-2013, 10:26 AM
Easy Mike
Easy Mike's Avatar
Size wise, yes, but you would not want an 82 crossfire hood on your 73.
Old 10-02-2013, 02:22 PM
4 speed
4 speed's Avatar
sure I would, that a 66 mustang tail lights, and a big assed CB antanee!
would wondering what might fit, so if someone had a an L88 on their 82, then I know I could use it on my 73.
Old 10-02-2013, 02:29 PM
Easy Mike
Easy Mike's Avatar
...sure I would...
That tells me you do not know about the stock underhood ducting on an 82 crossfire hood.
Old 10-02-2013, 02:56 PM
4 speed
4 speed's Avatar
o.k. , so now I am learning that a 82 won't work, unless it after market with out the stock under pinings.
maybe , it'd be better to save up and just buy a new hood.
Old 10-03-2013, 10:32 AM
Easy Mike
Easy Mike's Avatar
...maybe , it'd be better to save up and just buy a new hood...
I suggested that right from the git-go.
To 73 hood interchange
Quick Reply: 73 hood interchange
