Fender/Side emblems for my 79 C3
Old 11-18-2013, 06:04 AM
cantona222
7th Gear
cantona222's Avatar
Default Fender/Side emblems for my 79 C3
I just want to have your opinion: I am missing both Fender/Side emblems for my 79 C3.
2 Questions:
1-Is it possible to install the "Stingray" fender emblems on my 79?
2-If it is possible to install, Should I do it? or will it look "not" original.
Note: I really prefer the "Stingray" emblems over the crossed flag emblems.
Here are pics of my newly painted 79 C3.
Old 11-18-2013, 08:11 AM
Easy Mike
Support Corvetteforum!
Easy Mike's Avatar
Received 1,469 Likes on 1,248 Posts
Cruise-In II Veteran
79s did not have Stingray fender scripts. Some have crossed flags fender emblems. IIRC, others may not have had any fender emblems.
Do you have emblem mounting holes in the fenders?
Old 11-18-2013, 01:24 PM
cantona222
7th Gear
cantona222's Avatar
yes. there are emblem mounting holes on the sides. will the Stingray emblem fit?
Old 11-18-2013, 01:40 PM
mds3013
mds3013's Avatar
On my '77 the crossed flag emblem on the gas cap door is the same as the flags on the fender. Fender emblems are just stuck on with tape. The gas cap door emblem has threaded lugs held on with speed nuts. The holes in your fender look to be stock for a '79. Take the one from your gas door and see if the holes line up. mike...
Old 11-18-2013, 02:12 PM
Easy Mike
Easy Mike's Avatar
Originally Posted by cantona222
...will the Stingray emblem fit?...
Probably not without extra mounting holes. If memory serves, all the Stingray scripts have three mounting lugs, and some have four. AIMs give the hole centers, but not the actual placement on the fender.
Old 11-19-2013, 12:41 AM
cantona222
7th Gear
cantona222's Avatar
Thanks mds3013 & Easy Mike for the info. I think I will stick with the crossed flags emblem then.
To Fender/Side emblems for my 79 C3
Quick Reply: Fender/Side emblems for my 79 C3
