1981: High Idle After Driving
Old 01-02-2014, 02:15 PM
73737373's Avatar
Default 1981: High Idle After Driving
RPMs will not drop back to normal after driving it. They will drop to normal when I tap on the accelerator. Original Q-jet. No other mods.
Old 01-02-2014, 02:24 PM
fanmanbd
fanmanbd's Avatar
Could be as simple as leaning out your choke adjustment slightly.
Oh 81? Thought you had a 73737373 for some reason.
Old 01-02-2014, 02:49 PM
Shark Racer
Support Corvetteforum!
Shark Racer's Avatar
An 81 e4me qjet should work pretty much the same as the 4M or M4M QJets. My first guess would be that the linkage or throttle shaft itself is binding. Then a sticky choke.
When this condition is created, I'd recommend taking the air cleaner off and visually inspecting the linkage - is it against the throttle stop screw? If not, why? Is the choke holding it open (you'll see that the choke flap in the airhorn is not "straight up" as one indicator)?
Old 01-02-2014, 02:58 PM
SIXFOOTER
SIXFOOTER's Avatar
Agreed, the E4ME mechanically is pretty much the same as the older carbs.
Old 01-02-2014, 03:02 PM
73737373's Avatar
Many thanks. I'll look at it this weekend, if it's not too cold.
To 1981: High Idle After Driving
Quick Reply: 1981: High Idle After Driving
