ac compressor
Old Jan 2, 2014 | 12:09 AM
namvet6869's Avatar
namvet6869
Default ac compressor
Does an 81 have a sensor that the ac compressor will not run if the outside temp is too low. After fixing my ac this summer, I took the 81 out the other day when temp. was in the 20's. Just out of curiosity I turn it on and the comp. did not come on. I'm thinking this is the way the old systems were designed. Just checking!!!!!!!!!! Thanks
Old Jan 2, 2014 | 09:05 AM
doorgunner's Avatar
doorgunner
2026 Loser of the Year
I'm not sure about that A/C switch.....but it's good to hear that you made it back from "Beautiful Fascinating Southeast Asia"....
(I was there to "help" the NVA re-take Nam in '71-'73....Congress rationed our ammunition)!
Old Jan 2, 2014 | 09:12 AM
damoroso's Avatar
damoroso
Nope. Just a pressure switch. I'm not sure but the cold might effect the pressure in the system that might cause the switch to see a low pressure situation that might prevent the comp from coming on.
Old Jan 2, 2014 | 11:32 AM
namvet6869's Avatar
namvet6869
Welcome home doorgunner. I know exactly what you mean. I there 68-69, Security Police.
Old Jan 2, 2014 | 03:36 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
I'm with you, Namvet. I was thinking the compressor would not run if outside temps were cold. Not sure where I read that.
To ac compressor
