What is this part
Received 1,469 Likes
Cruise-In II Veteran
May not be Corvette. Where did you find it? Carburetor part?
God, I hope I'm right! I'm referring memory of the Tri Power set up on the Pontiac GTO's and have never seen those on a Goat. You can see the design, includes a rubber diagphram, sandwiched between two halves and a linkage. Hopefully, it's what I think they do. The GTO ran off the center carb and then the outer carbs kicked in. That the center carb, doesn't have those plenums, led me to think-guess, that's what they were for!
Well I decided I'm going to mount these back since they came on the car originally. Unfortunately the mounting screws are not sold anymore. Can someone please send me pictures or descriptions of the 6 screws needed so I can try to find something close?
Instant answer, no? Tedious, yes, but sometimes, it's what you have to do, to get results. Another route might be doing an Internet search for parts diagram, schematic, etc and you might get a hit. Use the casting numbers off've your carb too, in the search and it might just match a parts list.
Have you tried here? Screw set B3502.
http://www.chicagocarburetor.com/dia...ew.php?d=24737
http://www.chicagocarburetor.com/ite...php?item=27170
