Radiator Fan Electric
Hi all; 1982 Crossfire - recently had air pump, cat removed, installed tight tuck headers and true dual exhaust with Magnaflows. Noticed the electric fan is not hooked up to anything. See pic. I am assuming it was hooked up to the air pump stuff. What can I do to re-hook so that it gets power and turns on/of when temp gets 180?
Check for a sensor between cylinders 6 & 8 on passenger side of engine block. Fan wires attach to this sensor. Fan won't come on at 180 degrees. It will be well over that before fan comes on. What did you hope to achieve by removing the air pump, cat, and installing tight tuck headers and true dual exhaust with Magnaflows? Did you put in an O2 sensor?
Maybe he hoped to achieve a little more horsepower. What difference does it make what he did to his car.
you can change the sensor out for one that turns on/off earlier.
Thanks. The wires barely make it to ac compressor so I am assuming I need to extend. I will look for sensor however how does fan get power? I wanted true duals on the Vette and a deeper thriftier sound as well as performance. Keeping the old parts for future. Thank for your help.
Received 1,469 Likes
Cruise-In II Veteran
The electric fan is stock. Near the AC compressor in the wiring along the right fender skirt, you should find the harness plug for the fan. You'll need a connector for the fan motor pig tail.
The wiring you need is part of the "Starter Extension Harness" as Mike said it should be along the fender skirt somewhere. The temp switch is a 2 wire contact closure type as opposed to a 1 wire to ground type. The stock switch it set to 280*, Way too hot to do you any good in a healthy car under normal driving, even in traffic. The electric motor is also somewhat anemic IMHO, especially compared to what is available these days. If you don't mind spending a few More $ you might consider switching out and going all electric, Spall Dual for instance. It will do a very nice job pulling air when its needed even if your rad seals are not perfect and since its controlled by actual coolant temp will probably do you real nice. Also gived oportunity to clean up the engine bay quite a bit.
