Help with reinforcing front end
Is there any reinforcing pieces that helps align the hood with front nose piece. I took mine apart for painting and can't remember if there was something that connects to headlight bar to radiator support? Seems very fimsy
Received 1,469 Likes
Cruise-In II Veteran
Model year? Do you have the assembly instruction manual (AIM)? Do you have the radiator support out of the car?
You say you took something apart. What did youu take apart?
Yes I do have aim.
I did have the radiator support out but now lts in but where the point on the hood almost touches the front piece where the headlights are mounted doesn't line up. Hood is higher than nose piece. Its looks awful, like it needs support.
