1971 routing upper heater hose
Hi, My cars back together. Looking at some pictures of engine compartments I noticed that some people have the upper heater routed under the ac compressor to the intake manifold connection. Mine is over the top of the compressor. Does anyone know the correct route?
If the over the top of the compressor is correct is there a clamp I can use to keep it towards the front of the compressor? It is rubbing against the air filter intake.
Routing a '71 heater hose
Thank you.Iam sure I will get the answer. The hoses are new and I don't want the air filter snorkel to cut into the hose.I know I can make something but I like to get the proper clamp.
[QUOTE=2001convertable;1589306819]Hi, My cars back together. Looking at some pictures of engine compartments I noticed that some people have the upper heater routed under the ac compressor to the intake manifold connection. Mine is over the top of the compressor. Does anyone know the correct route?
If the over the top of the compressor is correct is there a clamp I can use to keep it towards the front of the compressor? It is rubbing against the air filter intake.[/QUOTE
Both hoses go around the front of the compressor through a hose retainer bolted to the A/C bracket below the clutch before then connecting to the water pump and intake manifold.
Received 1,246 Likes
The alternator belt goes on the water pump pulley closest to the engine then the air conditioning belt.
here is a pic of my 72.
hose under, correct belt installation
heater hose loop bracket.
a/c comp upper left, a/c comp belt, water pump right, black hoop bracket that heater hoses route through.
EarlyC34me (04-27-2017)
yes, about the belts they were on backwards. I realized that after a few hours after reinstalling the radiator and flipped them but not before I took the picture .
I just looked and I do have the bracket. The lower heater hose is running though it. Now I have to route the upper hose though. The only problem I have is the fitting on the intake is straight. Is there supposed to be a 90 degree fitting on top on intake to route the hose down to the bracket in front bottom of compressor?
The original hose has molded ends for the sharp turn to go under the A/C compressor like the link attached. Please make sure you get the correct ones for your year.
https://www.paragoncorvette.com/p-35...-hose-kit.aspx
I went and checked mine. They are also routed above the AC unit. It looks like I will be adding another project to get this routed correctly, and buying the correct hose for it.
thanks for the update on the thread
kdf
kdf
Thanks everyone for the great information and finding the correct parts for me.
I was wondering if the hose from the manifold would kink and now I see I need the correct molded hoses and a bracket.
Thanks again, Pete.
Thanks again, Pete.
