Picked up a 72'
#41
It's looking great.
I have been surprised at how many belt alignment issues I'm having on builds these days. Whether new brackets or 40 year old stuff it seem that I always have to tweak something. On the last cradle I had to put an 1/8" shim between the block and the bracket at the upper mounting bolt. That made the alignment OK but still not perfect.
I see you're on the fence about fuel pumps. With my '69 and '72 once I got to around 500 FWHP I had vapor look issues on hot days and changed both over to electric fuel pumps. The newer pump gas blends boil too easily. Some people seem to get away fine with mechanical but even with insulation on the lines I had trouble.
Jebbysan (01-20-2016)
#42
Dr. Detroit
Received 3,892 Likes
It's looking great.
Fuel pump wise I see what you mean and this engine will be right at that 500 FWHP you speak of.....hopefully the full braided line and high mount regulator/splitter will keep the fuel cool enough......the Radiator is pretty robust and I did the Fel-Pro extra water passage mod in the block, but it is a 406.
To be seen.......
I am VERY happy with the way it is turning out though......it is already nicer than my 66' and that was the nicest car I ever owned!
Jebby
#43
Dr. Detroit
Got my regulator and line kit today......I was very impressed with the quality of this for the money.....even the lines came pre-assembled.
Only down side is that I will need to run one of those 11" X-treme flat air cleaners.....oh well.
Coming together.....waiting for a set of ARP intake bolts as I robbed them for a customers engine....also waiting for my -6AN stuff to plumb the Holley pump....I did some clean up on the Team-G....I will get it cinched down and then prime the motor......run the wires....etc....
I know this isn't a heavy exotic....but I picked the parts out here for a well thought out look and for functionality....
Jebby
Jebby
#44
Jebby
Jebby
You have a really nice looking fun car there.
#45
Dr. Detroit
#46
If I text them to you would you post them? I have no idea how to get them from my phone to the puter.
You wouldn't happen to have a 3 groove water pump pulley for sale would you?
I did a BB conversion, and I need that pulley to hook my air cond. back up.
Those wheels look really good on your car BTW what are they?
#47
Dr. Detroit
I do not have a pulley, sorry......post a WTB....there are a lot of dudes that may have it......
Look on e-bay...there are a few.....
here is a nice one:
http://www.ebay.com/itm/68-69-70-C3-...-/370605327951
Jebby
#48
Sure...text them to 210-744-8204
here is a nice one:
Jebby
here is a nice one:
Jebby
#49
Dr. Detroit
Car fired right up.......sounded great during cam break in......
I have an oil leak in the back at the china rail so I will have to reseal the intake.....the .125 gaskets can be tricky to seal front and rear.....that is what I get for deciding to install the intake in the car.
Disregard the crummy butt connectors and MSD wiring......I whipped it up for start-up.
I will drop the oil/coolant....reseal the intake.....and after bleeding the brakes.....take it for a spin!
Jebby
Jebby
#51
Dr. Detroit
The oil drain for the head back to valley is right there too.....sooooo....I will have my mirrors ready for round two.
Jebby
#52
Jebby
Jebby
#53
Dr. Detroit
#54
Dr. Detroit
I fired the engine a few weeks ago and all is well.....
I had an oil leak and I am embarrassed to say that my coveted Dart heads had a leak on the upper accessory bolt...the one that hugs the head bolt on the inside. It was drilled a tad to deep and after removing the valve cover I saw the pin hole.....I plead the 5th and put a PTFE swabbed stainless button head in it. This stopped it, but not happy.
First time a set of Darts has let me down in almost 20 years.
Oh well.....moving on.....I drove it around the block.....killer power and instant response.....the old Magnum grind sounds amazing and runs very well.....I have 11 inches of vacuum.
One issue I have is that my 750HP has no vacuum ports and I only have one on the rear of the intake. I plan on purchasing an AED 4 corner plate with ports to solve this.
I will post a vid when I have more time.....
Meanwhile...a couple of things....
Some undercarriage detailing including a new pair of Poweder coated backing plates from member Teamtruett....and a new Pypes X-pipe courtesy of member bmansvette......thanks guys!
The undercarriage is a work in progress.....I will do more as time allows....I would like to have the VB&P control arms powdercoated....
Jebby
Jebby
#56
Nice install/combination to create power.
I can see you will have to use restraint..has to be tempting to hit the go pedal (keep an eye on the rear view mirror).
Your efforts have really paid off.
#57
Dr. Detroit
Tell me how you think it sounds
Phone ran out of memory......more vid rolling soon....
Did I happen to mention how powerful it is? LOL!
Jebby
Jebby
#59
Dr. Detroit
Ok....so I ordered and received my L-88 from ACI. I ordered it on 4/14....they had to make one.....it was done in four business days....they shipped Estes and I picked it up at the terminal on the 24th.......great service.
It came in a large cardboard box....first thing you notice is that it is about half the weight of the stock one......the fit and finish were about 9/10 as far as the part itself goes......
I bolted up the hinges....taped around the ends of the beak up front.....and set her down.....
I am impressed with the contours and gaps.....very close and not much to do there. The hood is also not duck-billed in the front center like so many I see......it does favor the front a bit...the holes in the hinges will have to be relieved about 1/8" to get it to move straight back.
This was worth the money and wanted to share for those who are pondering. If you tell them you saw it on E-Bay....you get $100 off.
This hood was $569 and $140 to ship.
One thing.....they do not sell the air chamber......I will have to pick one up. Why? I have no idea.
Any questions...feel free and shoot.
My friend and i are going to paint this and try to match the Mille Miglia red for now.....
It will also get "406" in the stock location with vintage font emblems.
Jebby
Jebby
#60
I had a '77 with a warmed over 400 SB. It was one fast car, that handled great. The 400 SB makes a great replacement engine, with lots of torque and can be tweaked to around 500 h.p. without too much trouble and expense. Cool car! Wise buy!
