battery cable length? routing
Likey more directed at modders than stock fans,
I need to buy new pos battery cable, so how long is the run from battery to starter?
Also have any of you modders found a routing you like better than stock?
Thanks,
Cheers,
Bats.
Thanks,
Cheers,
Bats.
I installed a disconnect switch under the center door This allows a short positive cable. with easy power on and off.
Received 3,227 Likes
I ran two 1/0 inside the car- One to the starter and one to the alt. I made my own cables and covered them w/ sheathing.
Also ran pos & neg 4 gu wire to some terminal posts to run my other stuff.
When w/ 2 6V batteries in the storage compartment to increase usable space.
DSCN5177 by Richard Hayes, on Flickr
DSCN5179 by Richard Hayes, on Flickr
DSCN4917 by Richard Hayes, on Flickr
DSCN5079 by Richard Hayes, on Flickr
DSCN4921 by Richard Hayes, on Flickr
And just in case I ever need to jump start- I used a BMW post/cable under the hood to easily hook up the jumper cables and get the power where it's needed - to the starter.
DSCN5182 by Richard Hayes, on Flickr
DSCN5181 by Richard Hayes, on Flickr
69vett I like that kill switch mount...I have a flaming rivers switch I scored near free a while back I planned to run and that does look like a great place for it.
Richard that is pretty darn sweet,
Do you have a picture of that 1/0 on the alt?
Do you believe tinned cable is worth the extra $$$?
Here's the pic of the alt- mounted down low- a custom Nippon Denso off a early 90's Geo Storm w/ AC!!! The trigger /ignition wires are sleeved in some left over Russel AN -6 nylon braided hose.
My cable is about 7ft-how I have run it. As the positive terminal is on the pass side connected to one of the 6v Optimas. Cable is "Streetwire" by Esoteric Audio from when I was in the 12Volt business- really flexible fine strand.
As far as tinned- Marine guys like it- but w/ the Vette the battery is protected pretty well AND if running a gel battery should be just fine w/o it.
DSCN5379 by Richard Hayes, on Flickr
DSCN2523.jpg~original by Richard Hayes, on Flickr
Nam Labrat
Received 4,321 Likes
I looked at three different Vette forums to find the cable length ........I didn't find any cable length----but I did find "cable length" threads with lots of opinions which had very little to do with the original post.
I really appreciate the members of this forum who give precise answers and sound advice(with pics)!
Thanks Bats and Members.......now I know how to place my battery cut-off switch that's been on the pegboard for a year!
I guess I am still gonna run my jumper lugs out to the rear,
I also see that all solid copper cable 1/0 on ebay is not the same the prices are all over the place,
Yeah peterbuilt gave us that but I do love the way 69vett mounted his kill switch and richards coolness but I am way curious how many amps that lil geo alt puts out?
Originally the alt was rated at 75A- I had it gone through and upgraded- and now its just under 130A. If you need anymore power- watch the video!
I would get some stuff from a local car stereo store- it's hit or miss on eBay- some of the cable out there won't bend- some will bend and break.
I used 9 feet length of #2 welding cable to make my own cable,
cut off about 12" off left over.
The battery switch disconnect has a removable handle, to make it a little bit more secure.
the middle storage door seemed to be the perfect location for the switch location.
