Looking for advice on purchasing first vette
72 vette purchase advice
I have been looking for a 69-72 big block vette for a while. I think I finally found one that checks all the boxes for me. Going to look at a 72 bb coupe tomorrow. Talked to the owner and the car sounds very nice. He is a mechanic and has gone through the car and has sorted through everything. The car is NOM 454 Big block, 4 speed, New Vintage Air, Pertronix Electronic Ignition, Factory Side Pipes, Dark Saddle Leather Interior. He has installed heat reflecting insulation on the interior to help keep it cool, replaced rear control arms, brakes and the radiator and the vacuum system. Car is very clean. He is asking $28k but says he has some room. I'm looking to stay under $25k. Thoughts?
<br >
<br >
<br >
<br >
<br >
<br >
<br >
<br >
<br >
Received 2,878 Likes
Hi B,
Car looks nice in the pictures.
2 things I see.
Regards,
Alan
The trim fits poorly…. why?…. windshield header problems?
The bumperette /grill alignment and fit is poor…. why?... was front end hit and not repaired well?
2 things I see.
Regards,
Alan
Good eye Alan,
I was thinking same thing as hood insert is not fitted very well.
Should all be fitted/ adjusted correctly especially after repaint.
Just an FYI, those tires haven't been made in a while.
Probably a good idea to figure 4 new sneaks in the budget shortly after if purchased.
25k seems strong but its a starting point.
Marshal
Marshal
It's also missing the black front air dam, this usually causes the car to run hot.
FYI - the steering wheel and shifter are after market replacements. It's also missing the black plastic shields that cover the headlights when retracted.
http://www.ecklerscorvette.com/corve...late-1972.html
Received 1,469 Likes
Cruise-In II Veteran
Buying a big block Vette can be a very thrilling experience. My personal opinion is that if this is your first C3 Corvette that you should take a knowledgeable person with you. As an NOM car with some alterations I think he is over priced from what I can see. Do you know if this is an original big block? Any documentation? What is the quality of the work that has been done. Others may have a different opinion but I don't see it bringing more than $20-22K at best.
Since this is a NOM car and a 72 which is probably the lowest value 69-72 model I understand the value is lower.
As a comparison, here is a car near me that appears to be a twin to that car, but is a claimed numbers-matching car. It's listed at 28K, and seller is willing to take any reasonable offer. That car has been for sale for at least four months, so he might jump at 25K. (Sorry, I know it's not near your area though.)
https://stlouis.craigslist.org/cto/5508888079.html
I think this goes back to a previous thread where someone was asking how much NOM affects price. In this case, where the engine gives this car a special provenance, and now that engine is no longer with the car, I believe it has a much greater effect to value than it would to a base engine car.
--Mike
What do you think is a reasonable offer to satisfy what he might be willing to take and what you might be willing to offer? If you want the car, you two will need to negotiate. You should be willing to go up a little; he should be willing to come down some.
My personal opinion, but he should have a lot of room to come off of 28K. Have you verified that it started life as a BB, thankfully on the '72s, it as easy as checking the VIN. If the fifth digit is a W, it's a BB, if it's a K, it's a SB.
--Mike
--Mike
I think this goes back to a previous thread where someone was asking how much NOM affects price. In this case, where the engine gives this car a special provenance, and now that engine is no longer with the car, I believe it has a much greater echinffect to value than it would to a base engine car.
--Mike
--Mike
Again, I ask, can you find another which fits your stated attributes at a better price? Condition being very important. I have no problem with people paying anything they wish for a numbers matching car if that's what their interest is. I am very skeptical you'll find a BB at a better price if this car is in very good condition. These cars are expensive to maintain, very expensive to paint, etc. I'd at least have a look, have someone knowledgeable look for big red flags other than numbers.
Whatever you decide to do, I strongly emphasize you should buy what fits your interests. I would never settle for a lesser car, a SB if I really wanted a BB, because people insist the SB is a better value. I question whether people who settle for something less to fit in are ever really happy with what they bought. If you feel more comfortable buying a true numbers BB, go for it, expect to pay $35K or more for one in good condition. Some go even higher. Condition is very important, numbers or not, they cost almost the same to repair. Numbers cars may cost a bit more to maintain having to rebuild original parts rather than replace.
Good luck with your quest.
Great advice, thank you! That is how I am approaching this. What would it cost me to add factory style side pipes, repaint, an AC system that actually cools the car, not to mention brakes rear drive train,suspension, vacuum system and on and on?
It's really work looking at. Remember to check for the rust.
The air cleaner is really thin and will effect performance and the fuel line was cheaply done.
The front grills look way off to me as well.
For $28K I would expect a no issues car.
I assumed he's referring to the gap. Could be sloppy reassembly? I don't know how much adjustment there may be on the lower ends of the bumperettes. I don't think you get much adjustment with the placement of the grilles. The windshield header misalignment may be poor installation. I'd take a closer look.
I wonder if an oem style air cleaner will fit? Thinking they went with thinner style due to hood clearance?
