Spal question
05-03-2016, 10:16 AM
Spal question
Can i splice the red comming from this connector? To use for the fan relays? This is the forward harness.
05-03-2016, 10:22 AM
Ooooppps i need the yellow. Nevermind
05-03-2016, 10:33 AM
While on topic 😊. I assume i need to cut this loop? And need to connect it to the yellows going to the battery?
05-03-2016, 10:35 AM
05-03-2016, 11:12 AM
05-03-2016, 11:42 AM
I need to pick up an orange (Ignition) any advise on witch one? 14 blower motor?
05-03-2016, 04:06 PM
St. Jude Donor '09
Quote:
Originally Posted by
cajos
I took it to the fuse panel (ign)
05-07-2016, 01:47 AM
redcruz1120
I'm a car electronics woos, help me out what cable did you use. Or did you go to the inside of the car?
05-07-2016, 12:53 PM
St. Jude Donor '09
cajos
Yes inside the car . It's the orange wire from your relay. There's a male spade connector on your fuse panel labeled ign.
