1971 tail light wiring
Old 05-28-2016, 09:06 AM
drdave69
drdave69's Avatar
Default 1971 tail light wiring
A good friend of mine is rebuilding a 1971 convertible and we are having trouble with the tail lights. Where do the ground wires attach at the rear?
Old 05-28-2016, 09:51 AM
Sonny71
Support Corvetteforum!
Sonny71's Avatar
Oldtimer
If I remember correctly you can attach the ground wire right by the license plate.
Old 05-28-2016, 09:58 AM
Alan 71
Alan 71's Avatar
Received 2,878 Likes on 2,515 Posts
Hi d,
There are several.
There's a ground at one of the studs for each of the lights, a ground for the license plate lamp, and one for the harness itself.
Regards,
Alan
Tail and brake light studs:
License lamp:
Frame rail location for harness and antenna ground.
Old 05-28-2016, 08:28 PM
drdave69
drdave69's Avatar
Originally Posted by Alan 71
Hi d,
There are several.
Regards,
Alan
License lamp:
Thanks a ton Alan. I was thinking that was how they needed to be routed but he had them screwed to the frame instead. I will let him know that they need to be attached to the housings. The antenna photo also helps since he still needs to install it.
Old 05-30-2016, 06:49 PM
0Willcox Corvette
Former Vendor
Willcox Corvette's Avatar
Received 1,813 Likes on 1,458 Posts
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
This may help you figure out the issues too.
The tail lamps have a bad history of issues ranging from grounds to the actual socket the bulb plugs into. We always tell people that if they are testing the rear lamps socket for power use a known working ground first because the brass socket the bulb hooks into can corrode between itself and the metal housing it is pushed into. You can remove these by driving them out cleaning them and then re-install.
Willcox
Old 06-07-2016, 01:45 PM
drdave69
drdave69's Avatar
He re-wired them as suggested and told me that all is well. Thanks.
Old 06-07-2016, 01:48 PM
Alan 71
Alan 71's Avatar
Hi drd,
Thanks for the update!
Does he realize that if ALL is well something is waiting just around the corner to bite him!?!
Regards,
Alan
To 1971 tail light wiring
Quick Reply: 1971 tail light wiring
