Detached convertible top deck lid latch bracket
Old 08-24-2016, 07:59 AM
TWINRAY
TWINRAY's Avatar
Default Detached convertible top deck lid latch bracket
The deck lid latch on my 1969 is held on by 4 bolts, 2 on a side. There are 2 "reinforcement brackets" IN the deck lid on each side to contain the bolts. One of mine detached when I took the latch off so I can only attach the lid latch on one side with 2 bolts. The reinforcement bracket WAS rattling around inside the deck lid and I was trying to get it positioned under the holes to somehow get it functional again. Now it must be stuck inside the lid somewhere because it doesn't rattle anymore. ( DOES ANYONE KNOW WHAT I'M TALKING ABOUT? lol). I'm sure I'm not the 1st person this has happened to. Suggestions please, thanks.
Old 08-24-2016, 08:25 AM
Alan 71
Alan 71's Avatar
Received 2,878 Likes on 2,515 Posts
Hi tw,
Are you describing a 'nut plate'?
Since I believe there's no metal frame in the deck lid was this 'bracket' you describe riveted in place and the rivets have let it loose? or was it bonded in place?
I looked at the deck lid pages in the AIM and the lock assembly is clearly shown but there's no hint as to how the 'bracket got there…. obviously before the top and bottom of the deck lid were bonded together.
Sorry! I feel for you but can offer nothing!
Regards,
Alan
Would 'well nuts' be strong enough to hold the lock in place?
Old 08-24-2016, 08:38 AM
TWINRAY
TWINRAY's Avatar
Well, if Alan doesn't have an answer, I'm definitely in trouble!😕 I didn't know what well nuts were but looked it up. If I saw what you mean, unless I put a hole in the bottom of the lid, it won't work. I appreciate you looking in the assembly manual which I didn't do, but will FWIW. I looked in 2 supplier catalogs and the reinforcement bracket isn't shown. It appears to have been bonded on as I don't see rivets. Rivets would definately have been more secure but they probably weren't thinking of us driving these cars 50 years later. I have get to shaking the lid to loosen the bracket as I can't have that rattling around after assembly. Thanks
Old 08-24-2016, 08:58 AM
TWINRAY
TWINRAY's Avatar
Here is a photo. The "reinforcement plate" for the 2 bolts on the left side has detached and is INSIDE the lid. What I don't get is why it's not rattling anymore when I shack the lid. It must really be stuck.
Old 08-24-2016, 09:35 AM
TWINRAY
TWINRAY's Avatar
Originally Posted by Alan 71
Hi tw,
Regards,
Alan
Exactly, the bolts are listed as "screw asm #384602" without showing the attaching/reinforcement plate residing IN the lid.
Old 08-24-2016, 10:25 AM
TWINRAY
TWINRAY's Avatar
I see now how this was attached.
the deck lid underneath was opened up to allowing this bolt reinforcement to be bonded. Then it was repaired/sealed up. I've gotten it to start rattling again. I will try with a magnet to route it to one of the end latches to get it out. It must be like a maze in there with maybe baffles because I can't just turn the lid various ways to route it out. Once out I will then open up the repair to rebond or maybe rivet it back in place.
Old 08-24-2016, 11:47 AM
TWINRAY
TWINRAY's Avatar
The bolt attaching plate that I fished out of the inside of the deck with a magnet.
Old 08-24-2016, 03:38 PM
Alan 71
Alan 71's Avatar
Hi TR,
WELL F-ING DONE!!!!
You can take the afternoon off with pay!
Do you have a little plan to get it back in place?
Regards,
Alan
Old 08-24-2016, 04:09 PM
TWINRAY
TWINRAY's Avatar
Hi TR,
WELL F-ING DONE!!!!
Regards,
Alan
Sure do!
Old 08-24-2016, 05:15 PM
69Vett
69Vett's Avatar
Corvette of the Year Winner 2017
2016 C3 of Year Finalist
good fishing job!
note to self, leave 1 bolt into all reinforcement plates always !
To Detached convertible top deck lid latch bracket
Quick Reply: Detached convertible top deck lid latch bracket
