Casting Number Question...
I located one of the casting numbers on my 80's engine block. Aside from dropping the oil pan, is there another way to tell whether or not I have 2 or 4 bolt main?
I've read through the documentation on mortec.com and while there was a TON of info, I couldn't find what I was looking for.
Is there any other way? The block casting is 14010207 and the head casting numbers are 462624.
I ask for the wisdom of the corvettefourm gurus.
Thanks,
Chris
Thanks,
Chris
Might start here :
SERIAL NUMBERS Body & Chassis Coupe 1Z87L89S400001 -1Z87L89S453807
The 5th digit varied: 8 = base, 6 = L82 (4 bolt).This will confirm "original engine" for your Vette.
I'll see what I can dig up on your casting numbers.
I forgot to mention that I have an L48. But, I remember hearing that if GM was out of 2 bolts, they threw in a 4 bolt.
Does that make sense?
14010207...350...80-85...2 or 4
Thanks,
Chris
Thanks,
Chris
& 2.02/1.60
Originally Posted by rihwoods
They may have done that.But looks like you may have to drop your pan.By the way,has your engine ever been re-built ?
Thanks for the head info...
Are these the 'smog' heads that everybody talks about? If so, what are my aternatives?
Head casting: 462624 76-87 1.94/1.50
& 2.02/1.60
g.m. kept no precise records of wich car got what blocks.your engine can be a 2 or 4 bolt main. unless you are over 400 h.p. it doesn't matter.a 2 bolt block with splayed cap 4 bolt are said to be even better than the factory 4 bolt.
99 times out of 100, an L-48 will have 2 bolt mains.
Check this out for me and report back please...There is a boss on the rear of the block right at the top of the bellhousing flange. Check it to see if it has been tapped for threads. I am betting yours is not threadded and that would indicate 2 bolt main. If it was tapped, I would say you would have a 4 bolt main. Do not tell anyone about this little bit of trivia and it will be our little secret here on the C3 CF board. Pinky-promise you guys!
-Mark.
-Mark.
-Mark.
-Mark.
