L-82 Cam Specs
L-82 Cam Specs
Just curious, what's the cam specs on a stock '78 L-82? Or better yet what cam replacement would be a good choice. Stock or tad higher. This is just a cruzer...
Emerging Vendor
Off the top of my head I think the lift is .450 IN/.460 EXH and duration@.050 is 222.
If you check Crane or Compa cams one of them makes a blueprint of this(same as 69-70 350 HP cam).
A modern design would probably work better though.
Greg
Greg
The L82 cam has MORE duration than the L79 350HP 327 cam. I would go with a more modern grind with a slightly bigger exhaust duration than the L82 cam. You need to give more specs on your Vette, is it an Auto? or 4 speed? Cruising around town or on the highway?
Ah. I see you have an L82. Leave the cam. Swap the heads. I went with the Dart Iron Eagles (sold as "Summit" heads) with 67cc chambers and 165cc runners. 650 bucks a pair.
I'm asking because I have 95k miles...it's almost time for a rebuild...I've heard good thing on this forum on the Lunati Voodoo cams, they make one close to thiese specs...
It will all depend on the specs to which you rebuild your engine. A lot of good things have been said about the Voodoo cams -- contact Lunati for a suggested cam once you have your rebuild specced out
