how hot and vacuum advance?
Will a motor run warmer with the vacuum advance connected to a ported (no vacuum during idle) or none ported (direct to intake vacuum). I'm now attached to a port on the on the carb with no vacuum advance during idle and wonder if it would run cooler with some vacuum advance during idle.
Location: At my Bar drinking and wrenching in Lafayette Colorado
Received 4,926 Likes
It will run cooler with the vacuum advance on a direct manifold vacuum source: More timing advance will run the engine cooler. The ported source will run it hotter and reduce emissions.
Okay, thank you Lars... I'll move it to the manifild source.
PS... I have the timing set to your specs found on the forum... 36 without vacuum (coming in a 2800)... and 18 at idle. With vacuum grand total of 52. Runs great. Just a little warm and hopefully the manifold source will help.
