Why charging with R134a on a Vette with a VIR A/C system is not the best.
I am by no means an expert on this but I have done a fair amount of reading on the subject of A/C and I found that the VIR unit does not have the POA valve adjusted properly for R134a.
It is set for R12 and as such the Evaporator pressure will not be low enough for optimum R134a performance. Now you can put R134a into a stock VIR system and it will work, but not the best.
Since there are a bunch of us with the old VIR system I suggest you read this link and then decide.
I had both R134a and now R12 in my system and I noticed a big difference when I went to R12.
Only reason is the VIR is calibrated for R12 and not R134a.
http://www.autoacforum.com/messagevi...AR_MSGDBTABLE=
If you want to purchase R12 legally you must have a 609 certification.
To get one you need to take a 25 question open book test and pay $20.
Here is a conversation about that:
Now as far as the cost is concerned, well, I cant help you out with that. I purchased (after I got my certificate) a 30lb can of R12 and I have enough for life now.
If you want to charge your A/C system with an alternative refrigerant then you might want to read the following. I am not saying selecting something other then R12 or R134a is a bad thing. You just need to make an informed choice is all.
http://www.autoacforum.com/messagevi...&threadid=9241
If you open up the VIR you can change it and adjust it. Nobody seems to know exactly how many turns to adjust the POA valve to make it work well with R134a.
I was looking for a LARS caliber A/C guy that did the research and could report what was needed to be done exactly but never found it.
I have a 71 with the separate POA valve (not VIR). I adjusted mine 1/4 turn CCW and it dropped my vent temp from 52F to 44F. This is with R134a. Don't know if the VIR POA is the same as mine but maybe a place to start?
I repaired and converted a '73 with a VIR system and the valve we got from Mid-America was set up for R-134A. we got vent temps that varied between 38-42 degrees on a 85 degree day. Worked for me!
Hans
Hans
I'm not an expert, but I bought a new VIR/POA unit several years ago for my original OEM A/C system and the valve was already adjusted for R-134a and came with the green seals. My vent temps are in the low 40's...I just wish the fan would move more air.
Location: Pottsville, PA. USA Home Of America's Oldest Brewery Yuengling
Received 2,239 Likes
I installed a new compressor, hose, and vir in my 75 last year and charged it with 134 and it blows 39o on a 85o day.
I didn't adjust anything.
Have you got pictures?
Originally Posted by zwede
I recently installed the C4 blower & cage and it moves alot more air. The big pile of leaves I dug out from the front of the evaporator didn't hurt either.
Originally Posted by 87bob
Have you got any pictures of your C-4 blower and cage conversion?
It's a simple conversion. You need to make a 1" spacer as the C4 squirrel cage is 1" deeper. I used two 1/2" kitchen cutting boards (polystyrene plastic, $5/ea at bed, bath & beyond). I cut the shape with a jigsaw. Used RTV for sealing. Electrical connectors are the same. There's a vent hose from the blower motor to the evap housing. My old one crumbled when removing so I made a new one out of some common rubber hose. A short piece of 3/8" hose into the blower motor hole. 5/8" over it and to the fitting on the evap housing.
I put a C4 fan/motor in mine. What I used for a spacer: I got a 6" PVC slip coupling at Home Depot and cut 1 1/4" length section off, then drilled the holes--it fits perfectly.
How much difference did it make with the C4 blower motor? Did you use the plug connector from a C4 and just splice it in?
The C3 connector fits on the C4 motor. No splicing.
I didn't have the same luck
I also bought a 1995 c4 motor and squirrel cage. Made the one inch spacer and sealed well. I can only tell a slight difference in the amount of air that is blowing through the vents. Not sure what to check next. Any ideas?
