'75 Catalytic Convertor
Old 10-08-2005, 05:41 PM
HDFLH67
HDFLH67's Avatar
Default '75 Catalytic Convertor
Here in New York, I have to have a catalytic convertor, since the 1975 originally came with one. BUT, it doesn't have to work since I am exempt from smog testing. (yes, that only makes sense to the politicians)
Any recommendations on the least restrictive cat out there at a reasonable price? Has anyone ever opened one up to gut it, and then welded back together?
Any other ideas appreciated! Thanks!
Old 10-08-2005, 06:01 PM
KenSny
KenSny's Avatar
I'd get a cheapo and gut it by running a straight pipe thru it - No restriction.....
Old 10-08-2005, 06:59 PM
Mike Mercury
Mike Mercury's Avatar
on my past 1975 (though Paul Borowski claims they didn't make any 1975 Corvettes... ), I simply replaced the cat with one of those "test pipes" My state wasn't doing any testing/inspection back then.
If this helps any, I gutted the "pre-cats" on my 2002:
http://mikemercury.home.att.net/precats.htm
this way - it still passes the visual inspection.
Old 10-08-2005, 08:11 PM
Pete76Shark
Support Corvetteforum!
Pete76Shark's Avatar
Before I moved to SC I lived in NJ and had the same situation you have.
I removed my stock cat and looked inside down the pipe. The element is very close to the opening of the inlet pipe, just take a long handled screw driver and have at it. You can get the insides out with no trouble. Then mount it back where you found it and when they look with the mirror it will pass...
Old 10-09-2005, 02:31 PM
vetsvette2002
vetsvette2002's Avatar
St. Jude Donor '13-'14-'15-'16
On your 1975, the catalytic converter is of the GM pellet design. There should be a large hex plug on the bottom of the shell. It is there to drain the useless pellets and refill with fresh pellets, no one ever did. Once you can get the pellets out, just replace the plug. You will have a noticably louder exhaust though. If you do not have the plug or can't get it out, just replace the converter with a newer design aftermarket high flow. This way you can still be running green.
Don
Old 10-10-2005, 08:52 AM
pauvil
pauvil's Avatar
Bash the center out, it will pass emissions no problem.
Old 10-10-2005, 10:30 PM
HDFLH67
HDFLH67's Avatar
Thanks All!
Old 10-10-2005, 11:36 PM
comp
comp's Avatar
some have a round plug knock it out clean and replace with a freeze plug a little grinding on the plug is needed
Old 10-11-2005, 04:59 PM
BigBlockk
BigBlockk's Avatar
Just do it right so you don't have to worry about it.
http://www.ecklers.com/product.asp?d...XLJBBUTA8E97K6
BigBlockk
Later.....
To '75 Catalytic Convertor
Quick Reply: '75 Catalytic Convertor
