Comp Cams Magnum 280h
Has any of you ever used a Comp Cams Magnum 280H in a big block chevy? If so how did it perform and idle( smooth or lopey)?
Running one in a SB now. Don;t know how they would compare though.
It's has a choppy idle.
Gary
Gary
I have that cam in my 427 happy with idle quality,lopy at 850rpm.good performane throughout rpms.headlights go up at idle I also use their roller tip rockers and their lifters with polylocks
I have one in my small block. Lopey idle, low vacuum but enough to operate all accesories with no problem. In a big block with anything more than a low compression engine it would probably be considered a mild cam.
I had this cam in a 396 BBC punched .090" over. Idled at about 850-900 RPM, had a very lopey idle...
BTW, the top end of the engine was essentially an L-88 setup, but I ran 8.5:1 Compression ratio. Had an M-21 4-speed, and a 3.90 Ford 9" Detroit locker in the back...
How did it perform? Well, I had to feather the clutch when pulling away from stop-lights, or the tires would simply break traction... the rear tires were 275-60/R17, the biggest meats I could fit without chopping the fender-wells, and the thing was a screamer, a serious handful to drive... it was a little soggy below about 2500-2700 RPM, but after that, it'd spin up FAST...
BTW, I had NO problems with the power brakes...
I think you'll like it...
Originally Posted by gbak
gtr1999:
What is your stallspeed with the 280 Magnum?
I'm running flat top pistons, do you guys thing I would have any problems with piston to valve clearance if i went with the 284H over the 280H? Its just something about that lobey idle that just drives me wild.
Originally Posted by blackbeauty74
Blue427, What type of pistons are you running? Also do you have any problems with your power brakes?
Thanks...
Thanks...
you should check the piston to valve clearance, I know the 280 doesn't clear a .100" dome, so on flats make sure you have good valve springs, the 284, I doubt you'll get away with without some shaving.
