Lubricating Your Strg Column Ignition Lock Cylinder
Old 08-10-2001, 09:57 AM
Jim Shea
Support Corvetteforum!
Jim Shea's Avatar
Default Lubricating Your Strg Column Ignition Lock Cylinder
I gave out some bad information the other day. :confused: I had indicated to use WD-40 to "unstick" a steering column ignition lock cylinder. Now I have been corrected. DO NOT use WD-40.
If your steering column ignition lock cylinder needs lubrication, the engineers at Delphi Saginaw say to use a small amount of MOBIL 1. Use a syringe or coat your key to get the oil into the moving parts.
WD-40 will dry out the metal parts and craze the plastic parts in the lock cylinder.
Sorry, I guess one piece of bad info in a year isn't too bad. :rolleyes:
Old 08-10-2001, 11:24 AM
paso
paso's Avatar
Default Re: Lubricating Your Strg Column Ignition Lock Cylinder (Jim Shea)
hey Jim your info wasn't bad wd 40 works right now! then if you follow it up with oil it won't happen again. :cheers:
Old 08-10-2001, 11:54 AM
GaryS
GaryS's Avatar
Jim, that is good information. For those that may be interested, Jim helped me, with diagrams and troubleshooting guides, fix my 72 key buzzer. I had a sticking lock cyliner. I used WD-40 to flush out the ignition lock cylinder (it was out of the car) and then used a light weight oil to lube the cylinder.
Gary
Old 08-10-2001, 03:55 PM
norvalwilhelm
norvalwilhelm's Avatar
I have used WD-40 many times in stiff frozen locks and on my ford F150 monthly. It worked for me in the past.
Norval :jester
Old 08-10-2001, 04:14 PM
thejaf
thejaf's Avatar
This may be odd, but what about electronic tuner cleaner? It cleans residue very well and leaves a very thin layer of lubricant.
To Lubricating Your Strg Column Ignition Lock Cylinder
Quick Reply: Lubricating Your Strg Column Ignition Lock Cylinder
