11.1:1 compression ratio and Hydraulic roller cams
Old 11-02-2006, 04:34 PM
Guru_4_hire
Guru_4_hire's Avatar
Cruise-In IV Veteran
Cruise-In V Veteran
Default 11.1:1 compression ratio and Hydraulic roller cams
OK so I have this here camshaft with 288/300 at 112 LSA with 4 degrees of advance ground in, with a 236/249 duration at .050.
I calculate my IVC to be 72 degrees
I calculate my static compression ratio to be about 11.1
When I enter my IVC into the KB dynamic compression ratio calculator I get
8.341 less depending on gasket bore, I assume a 4.1" gasket bore.
I was wondering is this gonna work with 93 octane?
Old 11-02-2006, 05:27 PM
holley505
holley505's Avatar
I had something pretty close in my camaro.
solid roller cam
245/256 duration .610/.617 lift
I ran the small dome TRW forged piston, dart II heads 64cc, block was cut .060 over. I ran MSD-6AL about 34 degrees. I could run pump gas without problem (93 only) car loved the race gas...
the trick is, the overlapp on the cam will lower the compression ratio because the values stay open longer..... I BELIEVE (TECHIES?)... my car was just under 11to1
It could run 13.1 to 12.8 on muscle and 11.7 on the gas.
SO I WOULD GUESS YES WITH A GOOD MSD SYSTEM....
Old 11-02-2006, 05:53 PM
MotorHead
MotorHead's Avatar
Location: Who says "Nothing is impossible" ? I've been doing nothing for years.
YOu should be OK, I am 11:1CR and run a 242/248 deg cam. Where you might run into problems IMHO is the added advance from a vacuum can
Old 11-02-2006, 05:54 PM
Guru_4_hire
Cruise-In V Veteran
Vacuum can?
Old 11-02-2006, 06:12 PM
zwede
zwede's Avatar
You're on the edge w/ aluminum heads. Over the edge if they're iron. Make sure you have a good cooling system. Cold air induction is a plus. You will problably have to retard timing in the summer.
Old 11-02-2006, 06:25 PM
MotorHead
MotorHead's Avatar
Vacuum advance, little can on the distributor
I was assuming aluminum heads ?
I just used the calculator and came in a ~8.4 DCR I run 92 octane and have never had a detonation problem
Old 11-02-2006, 07:41 PM
Guru_4_hire
Cruise-In V Veteran
Ahhhh OK.
Old 11-02-2006, 07:43 PM
gkull
gkull's Avatar
Received 1,330 Likes on 1,058 Posts
Originally Posted by Guru_4_hire
8.367 less depending on gasket bore, I assume a 4.1" gasket bore.
Who makes that cam?
Most 4 inch bore gaskets are 4.060
Old 11-02-2006, 07:52 PM
Guru_4_hire
Cruise-In V Veteran
Cammotion
Would you like the lobe numbers?
That might be a problem, the gasket bore thing. 8.379 DCR
Old 11-02-2006, 08:32 PM
Guru_4_hire
Cruise-In V Veteran
The Keith Black Piston
Summit number #
UEM-KB122030-8
Takes me a little further from the edge with its -7cc reliefs
This gives me a known pump gas friendly 8.171:1 and a static compression of 10.9:1
I still intend to ceramic coat the pistons, chambers, exhaust ports.
I am also plumbing in water to under the siamesed exhaust ports.
So will these KB pistons mess with my world?
Old 11-02-2006, 08:55 PM
mandm1200
Support Corvetteforum!
mandm1200's Avatar
Your engine is quite a bit different than mine. I'm running (trying to run) a 388ci on 94.5 octane and can't. Currently running a 280* duration hydraulic flat tappet cam with iron Vortec heads with 11.3 compression. With the alum heads and slightly bigger cam you may get away with it. You may not know until it's running. I'm definetly going to a bigger cam and a possible head gasket change (.038" to either a .051" or .062").
Using their calculatot my dynamic compression ratio comes out to 9.97. That quite a big difference than 8.3.
Old 11-02-2006, 08:57 PM
nastee383
nastee383's Avatar
I have an 11:1 383, 242/248 hyd roller, 8.2 DCR, alum heads, vacuum advance. I've run it with as much as 38 degrees plus the vac adv (12) with no detonation on 93. I was getting a "lean miss" during cruise at 38 so I backed it off to 36 and it went away.
Old 11-03-2006, 03:18 AM
Little Mouse
Little Mouse's Avatar
SCE-011069, .093 compressed, 19.729 compressed volume,
4.060 bore.
Old 11-03-2006, 05:44 AM
Guru_4_hire
Cruise-In V Veteran
You guys are running about 6 degrees more duration than I am. Those KB-pistons are more and more inviting.
Old 11-03-2006, 07:53 AM
63mako
63mako's Avatar
St. Jude Donor '08-'09
I wouldn't run KB Hyper's in my lawnmower. Especially since you know you will be on the verge of detonation. Ask Msvetteman. Do a search on these on the forum and other HP Chevy sites. My machine shop won't even build an engine for you if you want to use them. Go forged if you are that close to 8.5 DCR.
Old 11-03-2006, 09:11 AM
big_G
big_G's Avatar
I would go with SRP's (forged) if the budget allows. I wouldn't use KB's in 63mako's lawnmower either!
Old 11-03-2006, 09:44 AM
442olds
442olds's Avatar
In my BB I'm running 11.75:1(dynamic 9.121) with iron heads. I run 195 on a hot day 170 on cooler days. 92 Octane without any problems, at the track I have to run a little higher octane, but other than that I have no problems on the street. One other thing that is helping me out is .4" longer connecting rods.
I've run a 383 with 10.265(8.039) on pump gas without any problems either.
Be sure to setup the quench height properly and if you really worried about it have the piston tops coated and the combustion chambers coated. Make sure you debur the piston tops and chambers to make sure you don't have any sharp points that would create any hot spots.
To 11.1:1 compression ratio and Hydraulic roller cams
Old 11-03-2006, 02:20 PM
holley505
holley505's Avatar
Alum heads will help with pump Gas.
bigger cam with more Duration will help with compression and Pump GAS... of course a GOOD MSD system will help for sure.
Old 11-03-2006, 06:22 PM
63mako
63mako's Avatar
Old 11-03-2006, 06:24 PM
Guru_4_hire
Cruise-In V Veteran
I am looking at the KBs because they back me off the point of detonation.(8.171)
Its not a budget constraint that I am looking at a hyper piston.
Quick Reply: 11.1:1 compression ratio and Hydraulic roller cams
