Edelbrock #2116 Vortec intake
I'm new to Vortec heads and this intake - the Vortec head seems to have a cooling passage at the front and rear similar to the GEN I heads, but the Edelbrock Performer Vortec intake completely blocks the rear coolant passage. There's a note regarding an external coolant bypass with some fittings and a hose, but no information on what this is for, why I'd want it or how it's installed. Anyone have experience with this combo?
Sorry, newbie question :/
I'm struggling with a related problem. Here's all the info I could come up with:
Bypass Discussion
My Specific Problem
The response of the first poster that the problem went away when he rearranged the heater hoses, leads me to believe that his heater core is acting as the bypass in his cooling circuit.
I'm currently running one 1/8" bypass hole through the thermostat, but it does't seem to be doing the trick... my next step I assume is the heater bypass hose you mentioned... and now come to think of it, mine included the same parts but made no mention of their intended application.
I'll keep digging...
Bypass Discussion
My Specific Problem
Originally Posted by jackson
Vortec like all other sbc heads are meant for either right or left ... a water port in front of left becomes at rear when installed on right. It is normal that only front of manifold has water ports. Only a few intakes have water ports at rear. Just install it & put it out of mind ... it's a non-issue.
Further, indirect discussion about coolant bypasses...
Coolant bypass discussion
I've tried the 1/8" hole approach, now I think I'm going to a dedicated bypass hose and normal thermostat, hopefully it will alleviate the temperature spikes I've been seeing.
The bypass would go between the 5/8" water pump tap, and the 5/8" manifold tap.
Hope this helps
Hope this helps
Hope this helps
Hope this helps
Take a look at the alum vortec sbc intakes that GMPP sells ... only the one intended for highest performance race motors has any provision for rear water ports and even then there's not a xover. Also, look at arguably the world's most popular sbc alum intake ... EB performer 2101 ... it does not have any provision for water to cross over between rear ports. Gazillions of street/strip folks run it. Virtually every chevy powered CT racer in our region is required by track rules to run 2101 intake and NONE are modified to Xover at rear. Betcha dollars to donuts your OEM C3 sbc intake is same way.
If you're running one hellacious powerful motor making huge heat at sustained very high rpm ... then maybe you'll need rear water xover ... but if car's tagged & insured then it's unlikely it needs a rear xover.
Jackson, thanks for your patience. I headed out to the garage to take a really close look at some of my older intakes, and DMFAAH (don't ask that certainly is the case for my 1970 LT-1 intake and the others I had on the shelf. Learn something new every single day.
Again, thanks for your patience and support!
