Do I need to Prime the diff?
Old Nov 13, 2006 | 02:21 PM
genuine1980's Avatar
genuine1980
Default Do I need to Prime the diff?
The diff is out of my car and I cleaned it all out.
When I put the yokes back in to I need to prime the races with grease or oil? How about the new yoke seals or other parts.
The diff is completely dry... all of the old oil is completly cleaned out.
Old Nov 13, 2006 | 03:17 PM
SIXFOOTER's Avatar
SIXFOOTER
is it just drained out or washed out? If just drained no problem just refill with lube and additive. If it is in fact dry then pre lube and then put it back together
Old Nov 13, 2006 | 03:19 PM
genuine1980
I used brake cleaner to totally get all of the old oil and grime out. It is totally dry.
Now that I'm ready to put the new outer seals on and put the yoles back in... I'm not sure if anything needs to be primed with oil or grease.
Old Nov 13, 2006 | 03:38 PM
SIXFOOTER's Avatar
SIXFOOTER
Normally you should use assembly lube, but if you just fill it and rotate by hand it should be ok
Old Nov 13, 2006 | 05:57 PM
GTR1999's Avatar
GTR1999
Whe I assemble a diff I use grease on the rubber seals to lube them. I use some 90 wt gear oil on the bearing and journals on the yokes.
To Do I need to Prime the diff?
