Original tire size on a '71?
215/70-15 is the modern equivalent
The original F70-15s were 26.92 inches on diameter and that is the spec of the 215
The 225/70-15 are 27.4 inches and are wider and about a 1/2 inch taller than stock
215/70s are harder to find so most go with the 225 but they are larger than original
The 225/70 is the correct size for GR70-15 used 73-77 but big for the 68-72
