Effect on engine run without air cleaner
#41
#42
Originally Posted by noonie
I have seen several tests that show K&N filters allow more wear particles into the oil than a factory filter.
I guess do your own tests to be sure.
One oil analysis with K&N
Another with stock filter
Oil analysis w/ K&N air filters usually show the Fe and Si are elevated.
#43
do you have a cold chamber hood? if yes, use the L-88 filter, seal, flame arestor, and, drop down base. If you don't have the cold air chamber, then use, as many have suggested, the drop down base..I'm not sure if the L-88 has a longer drop than the aftermarket...but you can get an element and top that will fit under your hood. If the carb stud is too long, trim it.
My intake was 5-7/8" tall with the carb mounting surface machined parallel to the bottom. I had it angle milled to remove 3/8" from the front and now the carb sits relatively level. This made a big improvement but not quite enough.
I don't know who manufactured my hood, it appears to be hand laid. I measured from the cowl up to the raised portion at the back of the hood and it's 2". I was under the impression that these hoods were raised 3", or am I measuring at the wrong place?
#44
If anyone wants to do some interesting reading, go to the bobistheoilguy.com site and read up about what many have found on the K+N filters. As others have said in this thread, some of the UOA's with these filters are downright scary. I no longer run one on anything.
#45
CF JASOC Member
I wouldn't even run my lawn mower without an air filter.
