Old Apr 26, 2007 | 09:19 PM
bbeck's Avatar
bbeck
Default 496/8100
Has anyone swapped in a truck 8100 fuel injected motor? I would like to go fuel injection, and believe that this would be a good starting point. Then, later add some higher compression pistons, possibly different heads, and maybe run e-85. I did a search, but didn't come up with anything. I thought about building a 496 out of my 427, but the cost adds up real quick to what I'd be able to get a 8100 for with the FI. Anyone have any bad experience with these gm engines?
Old Apr 26, 2007 | 09:22 PM
Durango_Boy's Avatar
Durango_Boy
I'm interested in watching this one pan out.
Old Apr 26, 2007 | 10:05 PM
shafrs3's Avatar
shafrs3
The intake won't fit w/o the L-88 hood. The motor is optimized for low end grunt, runs out of steam in the upper rpm ranges. I bought an intake off of ebay just to see it in person, it's a two piece design. Air flows in a loop in the top half from the TB to the bottom half and into the ports.
Old Apr 26, 2007 | 10:22 PM
dgruenke's Avatar
dgruenke
I haven't seen anything like this yet. You got my attention.
Old Apr 27, 2007 | 12:39 AM
billcar9999's Avatar
billcar9999
I have the 8100 in my truck. It's reliable. You can buy go fast parts for it from Raylar. They call them Big Power Kits. Tbyrne sells the stuff on his site. There are a few guys that were going to go this route in their trucks. I don't know if they really did or not. Check out GM-Trucks.com
Old Apr 29, 2007 | 08:18 PM
bbeck's Avatar
bbeck
hey shafrs3, have you fitted this under the L88 hood? I was wondering if there would be room under that or if it would have to be modified. Does anyone know if the bellhousing or the motor mount locations change at all?
Old Apr 29, 2007 | 08:54 PM
SIXFOOTER's Avatar
SIXFOOTER
What truck is that out of?
Old Apr 29, 2007 | 09:07 PM
Durango_Boy
A co-worker has a 2002 Suburban C2500 with an 8.1.
Old Apr 30, 2007 | 01:33 AM
bbeck's Avatar
bbeck
the 2001+ 3/4 or 1 ton truck line-up
Old Apr 30, 2007 | 01:41 AM
bbeck's Avatar
bbeck
I have found out that the 8100 block has the same motor mount points as early small and big block Chevy's. Only now all bolt holes use a metric thread. Even the heads share the same exhaust flange pattern. Also, the turbo 400 bolts right up- converter and all. So shafrs3, could I get some dimensions from you from that intake? The height dimensions front and back would be great, and how far out the throttle body sticks out. Would it be possible to bolt the upper intake on backwards and take advantage of the cowl induction?
Old Apr 30, 2007 | 07:41 AM
Durango_Boy
Holy crap, so you're saying that with the exception of the metric bolts, the motor mounts are the same as the small and big blocks, and the exhaust is same as the big blocks?
I may have to get myself a 8100. What's the chances that someone makes a carbed intake for it?
Old Apr 30, 2007 | 08:11 AM
bbeck's Avatar
bbeck
I haven't checked into intakes for it at all yet- my idea was to run the EFI. It may even be possible to bolt on a set of aftermarket heads and intake from our era of big blocks. I'm not sure of the location of the head bolts.
Old Apr 30, 2007 | 11:46 AM
SIXFOOTER's Avatar
SIXFOOTER
Looking at the pics it looks like the upper intake will spin around and bolt up. But it also looks like the air intake is on the side not the front. Would be an interesting exercise. I was asking about this last week exploring some LSx options. I need to get out and get a look at one of these.
Old Apr 30, 2007 | 12:03 PM
Durango_Boy
When you find one, will you please take lots of pics and pass them my way as well? I'd appreciate it. Thanks.
Old Apr 30, 2007 | 12:14 PM
bbeck's Avatar
bbeck
I just realized that the pics of that intake is different from what I've seen in the past. What year intake is that? What did it come off from?
Old May 4, 2007 | 04:43 AM
bbeck's Avatar
bbeck
http://video.performancetrucks.net/v...85bfb6394e.htm
and
http://www.raylarengine.com/
raylar may be a little expensive, but this is what I've found for people upgrading so far. If he runs 12's in a 3/4 ton pickup with an allison trans, I imagine it would run pretty good in a vette.
Old May 4, 2007 | 10:14 AM
shafrs3's Avatar
shafrs3
I'm just now reading these posts, I'd be glad to take some measurements, I don't think this particular intake would be a good choice for high HP applications though.
To 496/8100
Old May 4, 2007 | 12:49 PM
bbeck's Avatar
bbeck
well, it would just be to start with. Just to get the FI going on a 496.
Old May 5, 2007 | 12:54 PM
shafrs3's Avatar
shafrs3
Here's a shot I took with a straight edge laid across to the top. The throttle body mounting pad is even higher, measuring 9 1/8". The oil fill pipe could be easily removed, or trimmed.
How much do you know about this block? I'd been assuming it was just a stroked Gen VI 454. Are the heads interchangeable with the classic big block design?
Old May 5, 2007 | 01:39 PM
Glensgages's Avatar
Glensgages
I agree.....
I figured all-along this was just a .030"-over 427/454-block, with a 4.250"-stroke crank in it:
I tried checking Pace Performance's web-site for details about the 8.1-liter crate-motor, but none are shown.....
