Disabling EGR valve
Old 08-17-2007, 01:47 PM
wes77
wes77's Avatar
Default Disabling EGR valve
I have 77 Corvette 350 with Performer intake with EGR . How do I disable and remove EGR valve and vacuum lines in Thermostat housing??
Old 08-17-2007, 02:00 PM
SIXFOOTER
Support Corvetteforum!
SIXFOOTER's Avatar
all you have to do is disconnect the vac hose from the carb to the TVS and cap it at the carb. Vac applied opens the valve. You can remove the EGR and put on a plate in its place if you want
Old 08-17-2007, 04:41 PM
comp
comp's Avatar
To Disabling EGR valve
Quick Reply: Disabling EGR valve
