alternator bracket
Old 05-17-2008, 04:23 PM
jhuff
jhuff's Avatar
Default alternator bracket
anyone know what the gm # is for an alternator bracket for a 75? I thought it was 3951337, but that doesn't bring anything up. Maybe the Chevy guys don't stock it anymore?
Old 05-17-2008, 04:46 PM
Artsvette73
Artsvette73's Avatar
The lower bracket 14015539 75-82
Old 05-17-2008, 06:38 PM
jhuff
jhuff's Avatar
perfect thanks
Old 05-17-2008, 08:53 PM
TPI BOY
TPI BOY's Avatar
How about the top one
Old 05-18-2008, 06:51 PM
ShinodaVette
ShinodaVette's Avatar
My book shows it as 460754 for 75-82 (EXC. 70 AMP). It doesn't show any alternative p/n for one w/70 AMP though.
Old 05-19-2008, 06:37 PM
jhuff
jhuff's Avatar
I had emailed gmpartsdirect.com about this also and this is what they said.
14015539 first design malleable metal alternator bracket.
14015510 second design aluminum alternator bracket.
Does anyone know what the deal is with the aluminum one? Would it be worth the extra 20 bucks or so?
Old 05-19-2008, 10:38 PM
carriljc
carriljc's Avatar
Default casting number on my bracket is 3951337
short water pump,
not sure about a 75, but you can look casting numbers on ebay and find these things. also, late 60's to early 70's chevy pickups used a short water pump with similar bracket.
3951337
Old 05-19-2008, 11:47 PM
Artsvette73
The 5510 is for the 80's aluminum. The 5539 early metal. Other than that I know of no other diffrence.
Old 01-06-2015, 09:03 PM
WHTDRGN
1st Gear
WHTDRGN's Avatar
Are these two brackets interchangeable? I have an 81 with the aluminum bracket that is broken. I can't seem to find another for less than $100, but the cast iron ones are much cheaper and I imagine more durable.
Thanks!
Old 03-23-2015, 10:56 AM
zygowsra
Support Corvetteforum!
zygowsra's Avatar
I have a nice used bracket # 3951337.
To alternator bracket
Quick Reply: alternator bracket
