Courtesy light problem on my 79
Old 06-30-2009, 04:00 PM
Lawton79
Lawton79's Avatar
Default Courtesy light problem on my 79
I think it may be the delay timer for the dome and courtesy lights. How can I check it or how do you bypass it? Help!
Old 06-30-2009, 04:14 PM
Roughrider
Roughrider's Avatar
If your courtesy lights are going on and off at odd times or not going off at all, it's likely the timer.
The courtesy light timer should be behind the glovebox in a '79. It's bright orange in color so you shouldn't be able to miss it.
I've heard of some who were able to bypass it but I don't know the procedure.
Old 06-30-2009, 04:23 PM
...Roger...
...Roger...'s Avatar
To bypass jumper the 2 whites together.
Old 06-30-2009, 04:24 PM
chazcax
chazcax's Avatar
I was told to bypass the delay timer you need to connect the two white wires. Cant tell you if that works because after removing the glove box on my 82 I could not find the timer!!!!
Wish I knew where to look??
Old 06-30-2009, 04:30 PM
...Roger...
Should be to the right of the glovebox. Your 82 might have a white delay box instead orange.
To Courtesy light problem on my 79
Quick Reply: Courtesy light problem on my 79
