Problem setting timing in my car.
Hi,
I have a problem with my INNOVA EQUUS 5568
The problem is that the "gun" dosent flash. Today I've tried 4 different timing lights, and I can't get any of the timing lights to flash, in my car.
What is my problem?
Car:
1969 SB 350/350 engine
MSD 8572 distributor, blaster 2 coil and 6AL
8,5mm silicone cables.
What is my problem?
Car:
Hi,
What is my problem?
Car:
What is my problem?
Car:
What Display are you using, Dew, Volts or Advance Tach.
http://www.jegs.com/webapp/wcs/store...-1&showValue=1
Advance Tach
I set it to 4 stroke (just above 3)
And the "flash light" (just above 2) is on.....
?flash light off?
I have a INNOVA 3568 and it works great. Should the flash light function be off. I thought that was so you could use it as a flash light/trouble light.
It still dosen't work, if it is on/off.
Also please remember that other "guns" dosen't work on my car (Snap On, Innova 3568 ect...)
St. Jude Donor '12
The fact that 4 different timing lights yeilded the same results most likely means its not an issue with the timing light.
Try an old or plain jane plug plug wire on #1. your wires may be shielded too well for the inductive pickup to work correctly.
I'd certainly try other wires than #1 - if no light will flash on any wire...I don't know where else to look other than at the plug wires having some sort of mondo insulation :/
The pickup is inductive, and if the engine is running then we know there's spark in the wire. Have you tried the gun on another car?
I come back to maybe it's those 8.5mm wires...but that seems goofy :/
The "funny" part is, that the old Chain HEI that I had, I had no problem.
I could set my timing with no problems.
The problem began after I got MSD 8572, Coil 2 and 6AL in the car.
