C4 ac blower fan on 71 c3
I would like to get more air flow from my 71 AC system. From reading other posts sounds like using the fan from the C4's will increase air flow. The C3 and C4 blower motors turn at the same RPM so changing the motor isn't an improvement.
Will all C4 blower fans (not motor, just the fan) fit on a 71 ac blower motor? Are any modifications required?
Thanks,
Roger
Thanks,
Roger
It did on my "77. Installation required a spacer (approx 3/4 inch because the C4 fan is longer. It certainly did blow harder.
If anyone is interested, this is for sale - I am in the process of installing a Vintage Air system, adapting the 68 to 76 kit to work in the changed 77 dash.
Anyone making the spacer? Seems like putting a C4 fan in you C3 is a no brainer. Seems like someone should be making this spacer!! I think you need 3/4 inch. Should be made of a non-thermal conducting material: nylon, phenolic, ...maybe even wood!
1 Post
Heres the templet I made for mine.. this paper one I made fits perfect but I noticed the copy I printed changed size a little. if the blower wheel just clears the center hole, it will fit right.
