1968 Ignition Switch wiring diagram
I pulled my ignition switch out on my 1968 and now having difficulty figuring out which wire goes where. I thought I had marked each one when I pull it off, but when I put it back together, now the starter will not engage.
Does anyone have a color keyed wiring diagram of which wire goes to which terminal?
I can make a drawing by hand if you need it or I can send by clock location. Most of those switches had written on them which wire went to what terminal.
I can only offer this and then check to see if my old harness still has the connector. If it does I'll let you know what color wire goes to each position.
I labeled only the ones that were in the shadows.
Great pic Rick
Batt = Red 12 gauge
Acc =Brown 12
Sol =Purple 12
Ign =Pink 12
Key- =Black 20
Key+ =Pink/black 20
Grd = unused,blank
Batt = Red 12 gauge
Acc =Brown 12
Sol =Purple 12
Ign =Pink 12
Key- =Black 20
Key+ =Pink/black 20
Grd = unused,blank
Parodi Cigar (12-31-2017)
I've saved your wiring legend and want to thank you Roger, you seem to be the go-to guy when there are wires involved.
