1972 C3 Engine / Emissions Vacuum Diagram
Old 07-30-2010, 02:24 PM
VetteTech81
VetteTech81's Avatar
Default 1972 C3 Engine / Emissions Vacuum Diagram
I am looking for a vacuum diagram, NOT FOR THE HEADLIGHTS, but for the engine and or emissions routing, ie distributor vacuum routing ect. I am trying to help a friend of mine. Thanks!
-=Rick
Old 07-30-2010, 02:27 PM
Easy Mike
Support Corvetteforum!
Easy Mike's Avatar
Received 1,469 Likes on 1,248 Posts
Cruise-In II Veteran
Your friend could use the assembly instruction manual (AIM). It shows the hose routing and color codes.
Old 07-30-2010, 02:43 PM
VetteTech81
I'm sure he could.. but if anyone has atleast 1 page with vaccum info for the emissions ect. I could print off for him that would be helpful. I know I've shared many diagrams in C4/C5/C6 forums over the years... Since that is what I work on mainly, I am not really a big help to him with service info, but would like to try to help him out if possible without waiting for or paying for a manual.
Thanks,
-=Rick
Old 07-30-2010, 04:01 PM
Alan 71
Alan 71's Avatar
Received 2,878 Likes on 2,515 Posts
Hi Rick,
Knowing which engine you're working on will help clarify what information you need.
Base, LT-!, or 454?
Regards,
Alan
Old 07-30-2010, 04:28 PM
VetteTech81
Originally Posted by Alan 71
Hi Rick,
Base, LT-!, or 454?
Regards,
Alan
I believe it's a base 350.. though they didn't say..
Old 07-31-2010, 09:38 AM
Alan 71
Alan 71's Avatar
Hi Rick,
Here's a photo of a base 72 engine.
1 small hose from the vapor canister to a nipple on the front of the carb.
1 large hose from the vapor canister to the pvc valve and then to a nipple on the front of the carb.
1 small hose from the distributor can to the TCS solenoid and then to a nipple on the side of the carburetor. The third port on the solenoid has a small foam filter on it.
Hope this helps!
Regards,
Alan
To 1972 C3 Engine / Emissions Vacuum Diagram
Quick Reply: 1972 C3 Engine / Emissions Vacuum Diagram
