Silv-O-Lite Piston question
Maybe one of the engine builders can help me out here. I have a set of Cast (not hyper) Silv-O-Lite 1436 pistons. I've read that the top ring gap must be increased on the hyper type pistons, is this true for the plain cast aluminum pistons too? I know its a strange question. Tim
Received 1,878 Likes
2020 C2 of the Year - Modified Winner
2020 Corvette of the Year (performance mods)
C2 of Year Winner (performance mods) 2019
2017 C2 of Year Finalist
No....just use the std .004" or so per inch of bore and you'll be fine. Current thinking is to run a few .000's more on the second ring than the top one.
JIM
JIM
additionally, 1436 has very short 1.540" compression distance ... unless the block gets severely decked it will likely have a poor (too-wide) quench and maybe low compression. CD about 1.560" is nominal.
I do Not like any cast or hyper piston from UEM; don't like several design attributes & don't like quality of machining. I guess UEM ok for the cheapest of non performance replacement rebuild? Suggest a similar cheap hyper piston from sealed power such as H631CP or H669CP or H345NCP; they're hyper but do Not require increased gap.
You local auto machine shop can help you choose and may work with you on parts cost.
