Broken hood release cable
This thread demonstrates how to deal with a broken hood-release cable. http://forums.corvetteforum.com/c3-t...ght=hood+latch
There is also information for installing a backup cable that can be accessed from under the car.
Good luck.
Good luck.
mine wouldnt release on the pass side. after i got it to release i found everything intack i noticed the plastic holding the cable running between latches was split and the wire had worked it way thru the split
. when the release was pulled the wire just popped thru.
couple months later buddy up street ran into the same problem.
something fellow members should check next time u pop the hood.
http://forums.corvetteforum.com/c3-t...uck-hoods.html
Once you get the hood open, this post shows how to fabricate a "just-in-case" release. Which reminds me, I intend to make one of these.
