80 Rearend how much oil?
how much oil does the rearend take? i have put 1.6 litres already. how much more? :confused: :confused:
Rod :cool:
Rod :cool:
Re: 80 Rearend how much oil? (Ingar, Norway)
thanks....cool site by the way. and i actually know some that has registered in the registry.
Rod :cool:
Rod :cool:
Re: 80 Rearend how much oil? (Rod Rodriguez)
usually fill,em till they just start to leak out of the fill hole and dont forget the posifluid additive :yesnod: :yesnod: :cool: :seeya
[Modified by One GM A Tech, 4:43 AM 4/17/2002]
Re: 80 Rearend how much oil? (One GM A Tech)
Yup... that's how I been doin' 'em for over 35 years.
Car/Diff has to be level though.
I mix the additive in with the first quart/liter of gear oil. That way, you don't have to mess around with trying to squeeze that little bottle of stuff into the hole or any other device.
[Modified by Tom454, 10:12 AM 4/17/2002]
I also need to add more fluid in mine ( 1980 ) , but their is the suggestion of the posi additive ? - is this something that is seperate from the rear end oil itself ?
Re: 80 Rearend how much oil? (FeedVaal)
I will have to add the Posi additive - was unaware that this should be added to the posi oil when topping up the rear end
is there a easier way to fill the case? i mean is there a pimp that we could use to fill it? :confused: :confused: :smash: . I'm tired of sqeezingand fighting :boxing with the bottles :cry
Rod :cool:
Rod :cool:
