Front brake disc rivets?
Old 07-04-2011, 06:20 PM
corvettedave383
corvettedave383's Avatar
Default Front brake disc rivets?
are the factory front brake disc's riveted on??, if so, how to you get them off?, also if you put them back on, is there a chance of runout problems
78 corvette
thanks
dave
Old 07-04-2011, 06:27 PM
mds3013
mds3013's Avatar
Yes, riveted on. Why do you want to remove the rivets and then reinstall the original rotors? mike...
Old 07-05-2011, 08:17 AM
muskegonbrake
Supporting Vendor
muskegonbrake's Avatar
You can drill or torch them out. If you intend to have them turned there is no reason to remove the rivets, just remove the hub from the spindle and have the entire assembly machined.
Old 07-05-2011, 08:20 AM
corvettedave383
I want to install new studs, so will have to drill out the rivets for that?, is it hard to drill them out?
Old 07-05-2011, 08:45 AM
Ironcross
Ironcross's Avatar
No need to cut the rivets out to change the studs......leave the hub and rotor together and just R&R the studs.......no need to separate the two parts unless your installing new rotors.....
Old 07-05-2011, 12:42 PM
corvettedave383
ok, thanks, what if I need to replace the front wheel bearings??
also whats the best way to get the studs out, just hammer them??
dave
To Front brake disc rivets?
Quick Reply: Front brake disc rivets?
