1982 Crossfire Injection
Old 08-23-2011, 08:27 PM
kj970
5th Gear
kj970's Avatar
Default 1982 Crossfire Injection
I have an 82 with crossfire injection. It mainly sits in the garage and collects dust. The other day I started it up, for the first time in probably a year. It starts but will not idle or maintain a steady RPM. It will only rev up and then act like it's going to die unless you pump the gas and rev it back up. If you don't pump the gas it dies. The only way to keep it running is to basically keep pumping the gas pedal as it revs up and down.
Any ideas? clogged something perhaps?
any help appreciated
Old 08-23-2011, 08:34 PM
terry82
terry82's Avatar
turn off the lights and worry about it next year .your gas is probably bad.your fuel pump may be bad and or you may have a vac leak.
Old 08-23-2011, 09:59 PM
7T1vette
7T1vette's Avatar
Received 2,713 Likes on 2,271 Posts
Your car has an ECM with an on-board diagnostic system to guide you as to what is wrong. Does the "Check Engine" light (CEL) work? It should light when you turn the key to ON position (which indicates that the bulb still works). If the bulb is not burned out, and the ECM is still working, the OBD system should tell you (by its trouble codes) what the problem could be.
Old 08-23-2011, 10:41 PM
wombvette
wombvette's Avatar
Worst thing you can possibly do is let a cross fire sit.
Old 08-24-2011, 12:44 AM
cyclops1032
cyclops1032's Avatar
Sounds like the injectors are dirty (gummed up from sitting).
Old 08-24-2011, 12:47 AM
EmNash
EmNash's Avatar
My money is on bad gas/ low fuel pressure.
Old 08-24-2011, 08:47 AM
wombvette
wombvette's Avatar
All good suggestions, but idle air controls are a common cause of idle problems after sitting.
Old 08-25-2011, 12:00 AM
couperdecar
couperdecar's Avatar
I'd dump the year old gas , and clean it all with some Sea Foam. Lotta guys on here love the stuff.
Old 08-25-2011, 12:23 AM
leebay
leebay's Avatar
Your TPS Throttle Position Sensor could also be bad if the check engine light is on and reading either codes 21 or 22
Old 10-10-2011, 09:02 PM
Knighted1
4th Gear
Knighted1's Avatar
I just bought my first 82 with crossfire today, and it is doing the same thing, runs rough and wont idle. This one has been sitting for over a year...when I pulled it on the trailer, the valves were rattling as well...I am going to start with the old gas, and take it from there...then I am going to start following suggestions on here ....
Old 10-10-2011, 09:08 PM
terry82
terry82's Avatar
http://www.crossfire.homeip.net/index.php?act=idxthey have lots of info to read and can offer lots of advice.
To 1982 Crossfire Injection
Quick Reply: 1982 Crossfire Injection
